Tip & How-To about Computers & Internet
How to flash your disk [USB]
How To Flash Your Flash Disk
[ USB ] Universal Serial Bus
  • First : Open Your USB Disk ( Like The picture )
  • There are two black Ships , marked with Three codes
  • A code has 6 Numbers , A VID Code and A Pid COde
  • copy all the codes to a bloc-note
  • open this site : http://www.flashboot.ru/iflash.html
  • Write The First Code Second Code and The Third code (Like The Picture)
1) Click Enter
2) The Site Give's You A lot Of Information
3) Choose You usb Disk Data (See The Picture)
4) Download The Flash Application
5) Connect Your usb Disk On The Computer
6) Open The Flash Application
7) It give's a button written on it : << Flash /or/ Preformat >>
8) Push The Button , Wait For A minute
9) Your usb disk Will Be Flashed ;)
Fix-shad0w
Please Rate .
Computers & Internet Logo
how to fix error message please insert disk into removable disk
which operating system ?
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Jan 04, 2014 | A-Data Technology Adata USB C802 8GB BLK...
how to fix please insert disk into removable disk
W 7
for XP or earlier
Jan 04, 2014 | A-Data Technology Computers & Internet
how to format flash drive? can't open the flash drive.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
w7
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamtion mark? ! or a Red X
right click to reinstall drivers.
If your computer came with a motherboard disk the drivers could be on it.
If you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts.
Click start click on my computer you should see your usb drive
right click on it then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
If you need more help with this post a reply
Hope this helps.
Nov 22, 2012 | Computers & Internet
cant install sdcz36-008g-b35
w7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamtion mark? ! or a Red X right click to reinstall drivers. If your computer came with a motherboard disk the drivers could be on it. If you can see your usb drive but its not working ports(com&lpt)right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts.
Nov 15, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
whenever i open my usb on a computer it always says please insert a disk
w7
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Nov 10, 2012 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
1,430 people viewed this tip
David Payne
David Payne
