Tip & How-To about Lands Phones
How to Check Your Cellphone Model Number
  • For Nokia : Check Off The Battery and look Inside The Phone Or Write : *#0000#
  • For Samsung : Reboot The Phone and the model appears on startup
  • For Sony ericsson : Check Off The Battery And Look Inside The phone
  • For Sharp : Check Off The Battery And Look Inside The phone
  • For Motorola : The Model Number Writed On The battery And Inside the Phone
  • For Siemens : Check Off The Battery And Look Inside The phone
  • For Pocket Pc (Phone) : Writed in the back off the Phone
  • For alcatel : Writed In The Back Of The Battery
  • For LG : Check Off The Battery And Look Inside The phone
Thanks , Fix-shad0w
Lands Phones Logo
my nokia phone is askin for a security code and i avent eva had one what is it pls help
There is No BL 4 model Phone in Nokia That is Nokia Battery type so please specify the Model Correctly..if you forgot the security code or Don't know the code means try default code 0000 or 12345 or 1234 if not works means You can get the Nokia Master Reset code from here
Onlinegsmunlock.com
and reset from security lock,Nokia DCT master reset code available there.
Oct 05, 2011 | Nokia BL-4C - Cellular phone battery...
phone memory full and its hanged > turn off the phone and turn back ob....this time it just blink at samasung startup logo..keep on blinking.
masri mutali hello there is no memotyry on the phone for it to boot up. If you can you do a hard reset on the phone. You should be able to reboot the phone. you can use 0000 or 1234. use this of you are still inable to reboot the phone . you will need to go to samsung.com and look for alternative hard reset for your phone. it will givew you step by step directions
Mar 18, 2011 | Cell Phones
nokia 5800 xpress music wont unlock and is flashing
after long search the forum and crafts on the phone all I even managed to repair the problem the phone to lock automatically when startup bug which he and impossible to unlock with unlocking the switch that unlocks the screen and keys, so here is what I do to reset it:
1-your smart phone with another and you must lock your chip with the PIN for your nokia you to save the PIN at startup
2-when the phone asks you to put the PIN code emergency call that is "112" to issue an appeal, you will find the digital bottom right of the screen when you click over the frame screen appears but impossible to put the code * # 7370 # for hard reset not panic please leave the call and put the PIN code 0000 or your own code if you change;
3-when you put the code the phone starts normally but the home screen something changes in the key to the vanishing locking and screen and keys shall be free;
4-so you can do the hard reset and the phone takes its original form
dw: I tested yesterday on my nokia 5530xm and is the only solution,
Dec 28, 2009 | Nokia 5800 XpressMusic Smartphone
i need the unlocking code for samsung u600 phone
Try 000, 0000, 111 or 1111.
Please rate FixYa!
Jan 13, 2009 | Samsung SGH-U600
622 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
