Tip & How-To about Computers & Internet
Crack office 2007
Microsoft Office 2007 all version crack (it work )
DO NOT ENTER ANY KEY OR DO NOT OPEN ANY MicroSoft Document file AND JUST FOLLOW THESE STEPS
STEP 1 == >
Open Regedit
go to
HKEY_LOCAL_MACHINE > SOFTWARE > MICROSOFT > OFFICE > 12.0 > REGISTRATION > { 30120000 }
And then Delete These three files
- DigitalProductID
- LicenseType
- TrialType
STEP 2 == >
Navigate to C:\Program Files\Common Files\Microsoft Shared\Office 12\Office Setup Controller\Proof.en
Inside the folder, edit the xml file in notepad/wordpad...
...find where it says
and replace "AlwaysInstalled" with "neverinstalled" and save.
Remember reply is must here
Computers & Internet Logo
i don't know my product key
Follow the steps bellow! Replace all * with html closed or opened. For example see here: http://img713.imageshack.us/img713/139/expt.png
Then follow these instructions:
1. Close all Microsoft Office applications.
2. Run Register Editor by clicking on Start - Run, and then type "regedit" in the Open box and press Enter key.
3. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration
Note that inside the registry key, there should be another subkey that resembles the following:
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{90120000-0030-00
­00-0000-0000000FF1CE
or
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-00­00-0000-0000000FF1CE
4. If there is more than one registry entries or subkeys that reference Microsoft 12.0 registration, open up each subkey, and then identify the product by the ProductName value data until you locate the subkey for the product which you want to remove the existing product license key.
For example:
ProductName=Microsoft Office Professional Plus 2007
ProductName=Microsoft Office Enterprise 2007
5. Once found the correct registry subkey, delete the following values:
DigitalProductID
ProductID
6. Close Registry Editor.
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
1. In Windows Explorer, brose to the following folder:
C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
2. Right click on Proof.XML file, select "Open With..." in the right click menu.
3. In the "Open With" window, select Notepad to be used to open the XML file. In Vista, if you can't see the Notepad option, simply double click the "Other Programs" to unhide it.
4. Scroll down to the bottom of the Proof.XML to locate the following lines:
*/Feature* *Feature Id="SetupXmlFiles" Cost="1248?*
*OptionRef Id="AlwaysInstalled"/*
*/Feature*
5. Change the AlwaysInsalled to neverInstalled so that the line looks like following:
*OptionRef Id="neverInstalled"/*
6. Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
7. You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
Aug 08, 2011 | Microsoft Office Professional 2007 Full...
Problem Printing Excel file
You may find it easier to follow the steps if you print this article first. .... Step 4: Remove any remaining 2007 Microsoft Office installation files .... Microsoft Office Standard 2007; Microsoft Office Home and Student 2007; Microsoft Office Basic 2007; Microsoft Office Access 2007; Microsoft Office Excel 2007 ...
support.microsoft.com/kb/928218
Jul 20, 2010 | Microsoft Office Home and Student 2007...
This sucks!
  1. Close all Office programs.
  2. Click Start, click Run, type regedit, and then click OK.
  3. Locate and then click the following subkey, depending on your version of Windows and of Office:
    32-bit versions 2007 Office system
    HKEY_LOCAL_MACHINE \Software\Microsoft\Office\12.0\Registration
    Office 2003
    HKEY_LOCAL_MACHINE \Software\Microsoft\Office\11.0\Registration
    Office XP
    HKEY_LOCAL_MACHINE \Software\Microsoft\Office\10.0\Registration64-bit versions 2007 Office system
    HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\12.0\Registration
    Office 2003
    HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\11.0\Registration
    Office XP
    HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\10.0\Registration
  4. Export the Registration subkey.
    You can make a backup of the values under the Registration subkey if the new product key does not work. To do this, follow these steps:
    1. Right-click the Registration subkey, and then click Export.
    2. In the Save in list, select a location to save the registration entries.
    3. In the File name box, type a name for the .reg file that you want to export, and then click Save.
    Note In steps 4a through 4c, you created a backup of the Registration subkey. You can restore the Registry settings of the Registration subkey by double-clicking the .reg file that you saved in step 4c. The contents of the .reg file are automatically exported to the Registry.
  5. Under the Registration subkey, there may be several Globally Unique Identifiers (GUID) that contain a combination of alphanumeric characters. Each GUID is specific to a program that is installed on your computer.
    Click a GUID. Then, view the version of Office that is listed in the right pane for the Productname registry entry. After you find the GUID that contains the version of your Office program, follow these steps:
    1. Right-click the DigitalProductID registry entry, click Delete, and then click Yes.
    2. Right-click the ProductID registry entry, click Delete, and then click Yes.
      For more information about how to identify the correct GUID for the version of the Office suite or program that you have installed on your computer, click the following article numbers to view the articles in the Microsoft Knowledge Base: 928516 (http://support.microsoft.com/kb/928516/ ) Description of the numbering scheme for product code GUIDs in 2007 Office suites and programs 832672 (http://support.microsoft.com/kb/832672/ ) Description of numbering scheme for product code GUIDs in Office 2003 302663 (http://support.microsoft.com/kb/302663/ ) Description of the numbering scheme for product code GUIDs for Office XP programs
  7. Open an Office program, such as Microsoft Word. When you receive a message that prompts you for the product key, type the correct product key, and then click OK.
Jul 30, 2009 | Microsoft Office Home and Student 2007...
product key
When the trial is over it will ask you to purchase the regualr version. When you say okay, paid your money then microsoft will unlock the trial version into a full version and send you the full key. Far as I know there is no legal way to get around that.
Jul 06, 2008 | Microsoft Office Professional 2007 Full...
157 people viewed this tip
David Payne
David Payne
