Tip & How-To about Burton P1 Snowboard Bindings 2008
How to wax your snowboard for travel
Before flying to a ski holiday do not scrape your wax from the bord
scrape only when you start to sku
Burton P1 Snowboard Bindings 2008 Logo
My Dept56 animated ski mountain. The skiers seem to heavy for the magnets in the ski run
Cut the friction on the skis or ski slope, use wax or soap to cut down on friction
Dec 16, 2014 | Sport & Outdoor - Others
wax in carpet
Yikes!! ok... first start by using ice to cool and harden the wax. Then use a dull knife like a butter knife to scrape as much of the wax up as possible.
Now... if the wax is an obvious color you've got a couple choices. 1. Patch the carpet with a hunk from a hidden area in the closet... OR... you can try to use a warm (not hot) clothes iron and a bunch of white paper towels to melt and absorb the wax.
See youtube for how to patch a carpet.
Mar 19, 2013 | Vacuums
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
Jan 17, 2013 | Winter Sports
what is the best brand of ski wax?
Brand is not so important as to the type of wax used. You want to make sure the wax is right for the conditions you will be riding. Some wax is harder than other wax and will work better in different conditions. Some wax is made for very cold temperatures -20 degrees Fahrenheit and below, some for intermediate temperatures, and some for warm temperatures, higher than 32 degrees Fahrenheit. Rub on waxes work well for an hour or two but quickly wear off. Hot waxing is best, but takes some time to apply and to learn how to do yourself, or usually costs at least $20 to have someone else do it for you.
It also depends on what type of riding you will be doing. If you are racing, you will want the best wax possible, and this is where brand and formula of the wax is important. It's best to talk to fellow racers in your area to find the best wax for that area's conditions if you are racing. Otherwise, any brand made for the temperatures you will be riding will be fine and any differences in speed from brand to brand will be unnoticeable.
Feb 15, 2011 | S3 Toko Hot Wax For Ski And Snowboard
1,028 people viewed this tip
Top Burton Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
