Tip & How-To about Computers & Internet
This tutorial will only work in windows xp.
On start up (before Windows loads),Immediately press F8 simultaneously.Click on "Safe Mode".When you are asked to log in, log in to "Administrator" (shouldn't have a password).Go to "Control Panel" by clicking on the START button.Go to "User Accounts".
Look for the account and either delete the password or change it.
step 2:
insert xp cd and boot ur system in bootable xp cd
then go to second repair option .After system restart 39 min remaining At the press shift f10 .At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel,change the password and run the repair setup.Now your administrator password changed
Follow the steps below to quickly find the administrator password on your computer!
1. Try leaving the password blank. More often than not, the Administrator password doesn't exist at all! Just press Enter without typing anything when asked for it.
2. Enter the password to your account. Often times, depending on how Windows XP was setup on your computer, the primary user account will also be the administrator user account.
3. Recover Windows XP administrator password using Windows Password Key. Windows Password key is a program reset any Windows password without reinstalling the OS.
4. Perform a clean installation of Windows XP. This is a last resort option. This type of installation will completely remove Windows XP from your PC and install it again from scratch. If you're just curious about your administrator password, I wouldn't suggest this extreme solution.
However, if you're needing the administrator password to access diagnostic tools and this is your last effort to save your PC, performing a clean install will work. Keep in mind that it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
More information and Tutorial to password from lost windows password website.
If you are running Safe Mode because you cannot get into Windows, you may want to first try
loading the last known good configuration.
To
get into the Windows 2000 / XP Safe mode, as the computer is booting
press and hold your "F8 Key" which should bring up the "Windows Advanced
Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note:
With some computers, if you press and hold a key as the computer is
booting you will get a stuck key message. If this occurs, instead of
pressing and holding the "F8 key", tap the "F8 key" continuously until
you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode
- If after several attempts you are unable to get into Windows 2000 or
Windows XP Safe Mode as the computer is booting into Windows, turn off
your computer. When the computer is turned on the next time Windows
should notice that the computer did not successfully boot and give you
the Safe Mode screen.
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once
you're done in Safe mode if you want to get back into Normal Windows
restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To
get into the Windows Vista and Windows 7 Safe Mode, as the computer is
booting press and hold your "F8 Key" which should bring up the "Windows
Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note:
With some computers if you press and hold a key as the computer is
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
