Tip & How-To about Heating & Cooling
Brazing aluminum pipe for automotive ac.
This tip can save you a whole bunch if you ever had a busted aluminum pipe on your AC line. A typical ac line is not only expensive but most of the the time auto parts would have to order them.
First you will need a propane brazing torch, brazing rods, and a clean wire brush.
Procedure; Fisrt clean the surface really good with the wire brush. The key to a working with aluminum is a very clean surface. Even if it looks clean the oxidation is not noticable. Set it all up so that you are comfortable while you are doing the brazing. Next, fire up the brazing torch. ( Do not use oxygen just plain propane torch will do the job much better.) Heat up the surface that need to be repaired. Now be patient and let the working surface get hot enough. You will know if it is hot enough because if you rub the aluminum brazing rod to the surface, it will smear and turn liquid and cling well to the aluminum pipe that you are working on. You have to rub the aluminum rod untill it builds up taking the flame away momentarily then putting it back on if it gets too hot. If you never done this before, practice on a piece of thin piece of aluminum first. With a little practice, you can repair many aluminum things in the house too. Even an aluminum radiator or the condenser or the evaporator in your cars a/c. Those aluminum brazing rods are actually harder than aluminum so the repair is permanent if done right, but they melt at lower temperature than aluminum. All these item can be bought at ace hardware. Home depot and lowes stopped carrying them in my area. So good luck and have fun on your new found money saving skill. Remember "clean surface" and get it hot enough first" Note* If the hole is too close to the rubber hose, wrap some wet rag to the pipe close to the rubber so that heat will not damage the hose.
Heating & Cooling Logo
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
Hi. I have a 2003 Ford Taurus that has a problem with the AC Clutch. There was a pretty nasty noise coming from my AC compressor, even when I wasn't using the AC. I took it in and the mechanic seemed
Yes in most of these instenses you can replace just the clutch assy. advance auto parts does offer it sepperatly. and they wont have to even open any lines. it just requires a special puller kit.
Dec 15, 2011 | 2003 Ford Taurus
why does my one pipe freeze when I run the ac and does not seem to cool very well
If the return line is freezing, as you describe, it typically means that you aren't getting enough air across the expansion coil, causing a large block of ice to build up inside.
Once that happens, you'll always get ice on the return line.
Try cleaning the filter or whatever the AC uses to keep the air clean.
Feb 25, 2011 | Samsung Heating & Cooling
home air conditioner made a loud noise outside and now it looks like the refrigerant is spraying out of a ruptured line. what can I do?
Let it fish then chk what the failure is. They can be repair but something caused it.Fan failure could have caused high head pressure but it would have had to be extreme or a weak spot in the coils
Oct 15, 2009 | Heating & Cooling
AC panel lights 05 camry
those bulbs cannot be replaced individually, you have to replace the whole ac control panel.
Sep 07, 2008 | 2000 Toyota Camry
685 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
