Tip & How-To about Video Game Consoles & Games
What to do When Your PS3 Won't Read Discs
There are several things that could be wrong. I'm going to lay out the stuff an average person could do at home. If NONE of these recommended fixes help, you are out of luck and have to take it in for servicing. Good luck!
Fix #1
1. Plug in controller.
2. Have system in standby mode (red light).
3. Hold down power button for a full cycle (will turn on and back off again).
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to.
7. Go to ONLY option 3 (restore).
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3.
9. Follow on screen prompt.
Fix #2
1. Fold a business card in half, while keeping the folded edge soft. You don't want a hardened edge.
2. Insert the card in the disk slot about an inch to open up the rubber flaps.
3. Follow the instructions on the air duster can for appropriate distance usage and get to spraying. Move back and forth evenly and hope for the best.
4. Follow-up with Fix #3 before trying again.
Fix #3
Insert a cd-rom lens cleaner. The brushes on there will give the laser a nice, solid scrubbing.
Fix #4
Reformat the system. If this step works, you will know that its a software-related issue. This is the last resort, so don't do this until you absolutely have no choice.
Recommendations for a Relaxed Gaming Experience
The PS3's blu-ray laser has a very powerful magnification lens. Because of the magnification, the tiniest speck of dust or fingerprint smudge will create disc skips or just poor gaming experiences. Do the following to help maintain your system:
1. Wipe of the dust and fingerprints before inserting the disc.
2. Dust the entire system (air duster) once every few days in order to ensure optimal gaming experience. Be sure to get the ventilation areas and to follow Fix #2's steps as well.
I hope this helps. I know you want to get back to your game, but be patient and keep a level head. Please take care and have a good day!
Video Game Consoles & Games Logo
where is the oil filter located in a 2006 Jeep Grand Cherokee Limited
Hello Debra Russ,
U may locate oil filter 4 2006 Jeep Grand Cherokee 2 way's.
1.) Open 2006 Jeep Grand Cherokee Glove Box, remove the 2006 Jeep Grand Cherokee owners Manual from glove box. Open owners manual to index page, locate oil filter page.
2.) Secure 2006 Jeep Grand Cherokee from moving fowards or backwards by blocking wheels in front and back which will NOT allow movement of said 2006 Jeep Grand Cherokee.
Using a small person of average build, average height, average weight, average intelligence, average physical appearance, move average said person with said average features of above near the 2006 Jeep Grand Cherokee, instruct said person to physically crawl under vehicle while laying on said person backside, (**** scraping on average dirty ground or average dirty filthy oil filled garage floor filled with oil filled kitty litter. Hand said average person an average shop light with an average wallmart brand soft white light bulb, light bulb will bo out very soon so move to next step ASAP. view engine while calling out all massive oil leaks INCLUDING a dirty oil caked oil filter.
Congradulations!
You found it when a black oil droplet drips from the oil filter into said average oil filled hair of said average person!
(insert smiles here)
FASTESTNASCAR
Dec 30, 2011 | Jeep Grand Cherokee Cars & Trucks
Personal Antivirus has invaded my computer. I have went to several websites and learned that it is a scam and that they just want to sell me software. I cannot remove this through add / remove programs. Can someone help?
Kill processes:
pav.exe
unins000.exe
Delete registry values(go to run and type regedit):
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Personal Antivirus_is1
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_ITGRDENGINE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ITGrdEngine
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer "PrS"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Personal Antivirus"
Delete files(use the search function to find files):
Personal Antivirus.lnk, Uninstall.lnk, pav.exe msxmlm.dll.tmp, drv1878004.exe.tmp,
Delete directories:
c:\Documents and Settings\All Users\Start Menu\Programs\Personal Antivirus
%UserProfile%\Application Data\Personal Antivirus
%UserProfile%\Application Data\Personal Antivirus\db
c:\Program Files\Personal Antivirus
c:\Program Files\Personal Antivirus\db
c:\Program Files\Personal Antivirus\Languages
(Where %UserProfile% is C:\Documents and Settings\Your username or C:\Users\Your username if you use vista)
reboot
Sep 19, 2009 | Microsoft Windows XP Home Edition
ripped outwell tent
log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
Jul 30, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
xbox360
This is a typical DVD drive problem. As I said several times on this forum already, your best bet right now is to call Microsoft and see if they would fix it for free 1 800 4-MY XBOX. DVD related problems are not easy to fix by the average consumer so I highly recommend that you don't open it and have a go at it yourself. You can actually make things worse. If you were near me I would gladly fix it for you.
Feb 09, 2008 | Microsoft Xbox 360 Console
622 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
