Tip & How-To about Office Equipment & Supplies
Error "HP product Assitance"
Dear all,
This is the error directly associated with the printer which is attached to the computer. There is many tips on the website but I will give you 100% resolution at one go..
any printer you are using it does not matter.. turn the printer off and go to control pannel// add and remove prog (XP comp) OR add and remove prog(Vista comp)..uninstall all the printer s/w as well as digital imaging device and hp solution center// apart from that also check that if there is any other printer driver installed which you are not using, just get rid of the s/w and restart the computer// after the computer boots up, then insstall the printer driver if you have the driver cd or go to the product website e.g www.hp.com and download the printer s/w in a fresh way.. connect the printer when it tells you to and you will smile after that..gusess why??? no error after that..
Thanks
Ashok Pandey
WHAT CAN I DO. I CANNOT GET MY HP DESKJET F4435 PRINTER TO SCAN . IT WILL PRINT AND COPY ONLY
you must go back to hp webside support and get the drivers for the scanner.
Sep 28, 2014 | Office Equipment & Supplies
hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
The printer simply says, "Unable to print. See troubleshooting and Routine Maintenance guide chapter in User's manuel." Thanks.
Hi Bang, give this a shot,
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 14, 2008 | Brother MFC 420CN All-In-One InkJet...
email scans
You can scan them and save them to a folder on your computer. Then e-mail them as attachements from you computer.
As long as there is a scanner program associated with your printer, it should work.
Jul 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
237 people viewed this tip
jasbo
jasbo
