Tip & How-To about Brother MFC 240C All-In-One InkJet Printer
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
Brother MFC 240C All-In-One InkJet Printer Logo
not printing
First disconnect the printer from the computer, next turn off the printer off and then while holding the on button down turn the printer back on this should print a test page. If the printer ink is goo you might have to replace the print head of the printer.
http://www.retrevo.com/support/Brother-MFC-240C-Multifunction-Printers-manual/id/1071ag216/t/2/
Oct 19, 2013 | Brother Multi-Function Center MFC-240C...
how to scan to an external hard drive from brother printer
Can't get the Brother MFC-240C printer to print. I have everything connected.
Oct 29, 2012 | Brother MFC J6910DW - Multifunction fax /...
where di i get info for my brother MFC-240C ,
You can all your Borther MFC-240C information from this manual.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
If this information useful for you please give me 4 thumbs up vote.
Thanks
May 23, 2010 | Brother DCP 165C Compact Color Inkjet...
Brothers MFC-240C not printing in color???
Do you have it set to print in black and white as the default? Go into the print driver, under Color Management, and select Color.
May 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
4,899 people viewed this tip
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
