Tip & How-To about Dishwashers
Dishwashers / wiring ,
If repairing or changing parts . make sure you mark the wires so you can reinstall them correctly. as if you don't you can damage micro prossers and other expensive parts .. mm . collor tape works good and draw a picture !
Dishwashers Logo
I switched my Beyond Micro Mobile Disk from one computer to another and it will not recognize it. I don't have the install disk that came with it. Any ideas?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 09, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Not sure how to replce spark plug wires from the distributor need help please send info
change one spark wire at a time on the distributor.buy new set of spark plugs wires remove them from box.match old wires with new wires to use the correct length to each cylinder.now if you need to change distributor cap.mark location distributor cap.number tag plug wires on the distributor cap so you can remove plug wires on distributor cap so you can replace cap and rotor and put wires back on the distributor cap in correct place.remember change one plug wire at a time so you wont get confuse.
Apr 15, 2011 | 1992 Ford Tempo
head gasket change
to remove head gasket first take off the valve cover and locate head bolts .make sure one is not broken . then remove timming belt cover and set engine to top dead center by the mark on the crank pulleyengine drive belt will also need to be removed.loosen timming belt tension ,mark belt osision and slide belt from camshaft gear .sometimes its easier to remove the gear.disconect fuel lines ,exuat pipe from manifold ,and sensor wires ,sparkplug wires and any other vacum lines wires ,ect ....that are conected the the cylinder head. before removel disconnect battery and drain cooling system. remove the head bolts ,inside and work to the outside in a circle.may need to pry head from the engine block careful .reinspect to make sure all hoses and wire ,lines are not still attached..always seems to be one thing that will still be attached..after head is removed ,you should be able to see where the gasket is damaged. clean all mating surfaces off engine block and head toinspect for cracks and damage.make it extra clean....razor blade scraper, sand paper ,brakecleaner and lots of shop towels. that is the most important to have clean surface ...install new gasket and reinstall head bolts to the proper tourque specs. parts guy can tell you if you dont know. when the head bolts are tight, this is a good time to drain oil and filter and after repair is finished install new 50/50 coolant. good luck with your repair
Feb 16, 2011 | 1994 Ford Escort
Tried to adjust temp of refrigerator and the panel went crazy, flashing through the various settings. Not sure what to do.
need a model # and ser # off the machine itself to give correct ans and part that has failed .. this is what i think . your machine uses a prosser with sensors and the prosser has failed . this can cause the flashing and how knows what . some models the ice mker will keep opening the ice door and never quit and the flashing controls . . to correct you will need to replace the controls in the frig side .. mm / hope this helps . mm
Nov 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
powers on no pic
there are many cause for it 1/vj has gone change it to check it.2/ wp/vista progrram is damage repair it 3/ ram may be damage change it to check it. mother bord may be damage change it to check,prosser may be damage change it check. last u may change high graphic- press f8 then u can correct require graphic....thanks
Jun 13, 2009 | ViewSonic P810 21" CRT Monitor
236 people viewed this tip
Top Dishwashers Experts
