Tip & How-To about Facebook Social Network
Hyperlinked image on your facebook page using FMBL
To add a hyperlinked image to your fan page for a logo OR some other use follow these easy steps:
  • Make sure you’ve installed the staticFBML application
  • Make sure your image is the right size (max 160 pixels wide) you can resize this in either Adobe Photoshop OR similar package.
  • Load your image into a photo album on facebook even your own web server if you have one I use ImageShack for ease
  • Check out my tip HERE for help with adding SWF to your facebook page and weblogs.
To make the image appear on your fan page wall, follow these steps:
First go to your fan page and click Edit Page (just below your fan page picture)
Click the pencil icon on the right of the FBML application in your list of applications, shown here are two that I have already created.
Add the Title you want displayed above your image/icon/logo then in the FBML area, paste the following code, replacing the items in between the ” to reflect your image. Note you mayneed to can change or delete the width and height information.
I have shrunk the screendump for ease, this window is much bigger. If you can't get this to work on your FMBL I have included an example below for you to test.
Facebook Social Network Logo
My scanner won't scan
Check that all the needed drivers are installed for your scanner.. If the computer is able to detect the scanner it should scan..
Follow the steps below
Step 1: Open the Kodak AiO Home Center software (make sure to upgrade to the latest version) (hyperlink "version" to http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7895&pq-locale=en_US)
Step 2: On the home screen, select "Scan Documents and Pictures”
Step 3: On the Scan screen:
  1. Select "Document" and "Black and White" and be sure that Perfect Page Technology is applied (it's selected by default for document scans)
b. Click "Next"
Sep 07, 2010 | Kodak Office Equipment & Supplies
hyplinks do not work in Outlook 2007. they used to work, not sure what made them stop
Fix 1: Start by Resetting Your Default Browser Most times, I can fix my Outlook hyperlink problem by resetting my default browser to Internet Explorer. I start with this step even if I plan to use Firefox as my browser. The reason I choose this path is I’ve had better success and it takes me closer to my end goal.
To make IE your default browser,
1. Open Internet Explorer
2. Click Tools from the menu
3. Select Internet Options.
4. Click the Programs tab
5. Click the button labeled Make Default.
6. Click OK.
7. Test a hyperlink in Outlook to see if the web page opens in Internet Explorer.
Fix 2: Reregister Windows DLL Files Even after resetting your default browser you still can’t open hyperlink in Outlook, it could be one or more registry keys is damaged. The solution is to reregister some of your DLL files. The process may sound intimidating, but it’s easy. There are 6 files to register based on your system. Some configurations use shdocvw.dll and others use shdoc401.dll.
To reregister the DLL files,
1. Close all open programs.
2. Click the Start button.
3. Select the Run… command. Vista users can type “run” in the Start Search textbox.
4. In the Open: textbox, type regsvr32 followed by a space and the file name.
In the screen snap below, I’ve used the first file Shdocvw.dll.
5. Click the OK button. You should see a message showing the process succeeded.
6. Click OK to dismiss the message.
7. Repeat the procedure for the other DLL files.
  • regsvr32 Shdocvw.dll (Some system use Shdoc401.dll instead)
  • regsvr32 Oleaut32.dll
  • regsvr32 Actxprxy.dll
  • regsvr32 Mshtml.dll
  • regsvr32 Urlmon.dll
  • regsvr32 Shell32.dll
8. As before, test to see if your Outlook hyperlink problem has been resolved.
Fix 3: Reset the (NONE) URL File Types If you’ve gotten to this part, I have to figure your Outlook hyperlinks are still broken. Don’t fret as I have another fix to try. My guess is someplace along the line your file associations broke. This is the mapping Windows uses to a file type to program. A common mapping might be .XLS files with Microsoft Excel. In this case, we need to check URL mappings.
To set URL file associations,
1. Open My Computer.
2. From the Tools menu, select Folder Options…
3. Click the File Types tab. A long list of Extensions and File Types appears.
4. Scroll down till you get to (NONE) URL:HyperText Transfer Protocol
5. Click the Advanced button.
6. Select the bold open item. *
7. Click Edit…
8. Click the Browse… button
9. Navigate to where Internet Explorer is located. (For most PC, it’s at C:\Program Files\Internet Explorer\iexplore.exe)
10. Add a space and %1 to the end of the file name. (e.g. "C:\Program Files\Internet Explorer\iexplore.exe" %1)
11. Click OK.
12. Click Close.
13. Repeat the process for (NONE) URL:HyperText Transfer Protocol with Privacy.
* If open doesn’t show, click New and type open in the action box.
Back to Firefox (Optional) Once you get the Outlook links to open in Internet Explorer, you can change your default browser to Firefox. This should roll down to Outlook so any embedded hyperlinks will open in the correct browser.
To set Firefox 3 as your default browser,
1. Open Firefox
2. Select Tools from the menu
3. Select Options…
4. Click Advanced
5. Click the Check Now button
6. Click Yes if the default browser is not set.
7. Click OK.
Nov 20, 2009 | Microsoft Office Professional 2007 Full...
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
233 people viewed this tip
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
