Tip & How-To about Computers & Internet
How to disable Driver signing in Windows 7?
How to disable Driver signing in Windows 7? Go to the Start menu and type cmd.exe in the Search Bar. Right click on cmd.exe and choose Run as Administrator.
If you have the UAC turned on, choose Yes to proceed. Otherwise, you should see the command windows opened already. In the shell window, copy paste the following and hit Enter.
bcdedit.exe -set loadoptions DDISABLE_INTEGRITY_CHECKS
bcdedit.exe -set
TESTSIGNING ON
You’ll get a confirmation that the operation completed successfully, as you can see below:
Restart your computer for the changes to take effect. You’ve just disabled digital driver signing in Windows 7.
Computers & Internet Logo
How do I reset the password on the windows 7 home page
Windows has a built-in security system that requires a user to type in a password to get to his personal account.
Only an "Administrator" account holder can make software changes to the computer.
All other users, including Guest users, need the permission of an Administrator to make any system changes.
However, if you have a guest account and need to access the Administrator account to make changes, you can do so via the Command Prompt feature.
Log in to your Guest account in Windows.
Go to "Start" > "Search" and type in "windows/system32/cmd.exe" to find the Command Prompt feature.
When the file appears on the search menu, drag it to your desktop.
Leave the search window open.
Right-click the cmd.exe file on your desktop and choose "Rename."
Type "sethc.exe" for the new name and click on an empty area next to the file name to save the new name.
Right-click on the "sethc.exe" file and click on "Copy."
Go back to the open "windows/system32" folder and right-click anywhere in the folder.
Select "Paste" to put the "sethc.exe" file inside.
Choose "Yes" when asked if you want to overwrite the current file.
Go to "Start" > "Log Off." It will bring you back to the User Account menu.
Press the "Shift" key 5 times in a row.
The Command Prompt will open.
Type "net user administrator [password]" and insert a new password in the [password] section.
Press "Enter" to set your new password.
It will bring you back to the User Accounts menu.
Click on the Administrator User Account and type the password you just set to log in to the account.
Dec 22, 2011 | Compaq Computers & Internet
my asus m50vc don't hibernate with win 7
You could either be out of room, meaning you have less Hard Drive space than RAM you have. Or hibernation could be disabled. You can re-enable it through Control Panel - Power Settings.
Mar 01, 2011 | Computers & Internet
how i can download afree cmd.exe
cmd.exe, also known as the command prompt, is the command-line interpreter on Windows PCs. You do not need to download it it is already a part of Win XP.
All you need to do is click on Start, select Run and in the dialog box that opens type "cmd" and press Enter. A command prompt window will open.
Jan 10, 2011 | Microsoft Windows XP Professional
203 people viewed this tip
David Payne
David Payne
