Tip & How-To about Dishwashers
Food particles left on the dishes suddenly !!!!!!!!!
Well this answer takes the cake, for about 3 months I've had problems with my dishwasher leaving "grit" on my dishes. After taking the inside drain area apart of my dishwasher, running a qt of CLR, gallon of vinegar, and any other product that someone mentioned or I saw in the store, THIS IS THE ANSWER TO THE PROBLEM.
There are 2 screws at the top of the dishwasher that hold it in place under the counter, well when the builder installed it, they only put 1 screw in. Hence the dishwasher after 6 years got pushed back ever so slightly on 1 side and obviously was "pinching" the drain hose. Pulled it forward, put a screw in, to lock it in place and it appear to be working like new.
I am also one that thought that the upper arm was getting water, well the upper arm rotates alternately with the bottom and its doing its job as well. Good luck everyone - Jo. Calgary, Alberta "Happy Stampeding"
Dishwashers Logo
grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
kenmore dishwasher leaving a lot of water on door, bottom, wall and dishes! it STINKS!
The pump could be leaking. The drain could be plugged - hence the smell. Taking a look underneath could reveal what needs to be fixed. I don't have an answer for why dishes are still wet even after a hot wash and heated dry but perhaps it is related to the other problem
Oct 22, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwasher is leaving grit and dirt on dishes. I have cleaned filter, but nothing changed.
run a load without dishes and see if it drains properly if not your drain hose is pluged or its not draining properly
Aug 23, 2009 | Dishwashers
my new ge dishwasher let my glasses and dishes uncleaned
I had a similar problem. Mine was leaving hard water deposits on my dishes. He had me take all of the metal out of the dishwasher (silverware, pots and pans, etc. Then run about 3/4 of a cup of Santeen de-limer through it. IT would clean the inside of the dishwasher nice, and would fix the problem. Unfortunately the hard water deposits would come back after a month or so, but would again be cleared by the Santeen...
Jun 11, 2009 | General Electric GLD69 24 in. Built-in...
347 people viewed this tip
Top Dishwashers Experts
