Tip & How-To about NetGear ReadyNAS Duo RND2150 NAS server (S6819023) Network Storage Server
How to setup your Readynas to telnet mode
Steps on how to set your Readynas to telnet mode.
note : this is only for desktop type of Readynas
1. Turn off the nas
2. Get a pen or a paper clip that will fit on the reset button.
3. Hold the reset button while the power is off.
4. Turn on the Readynas after 30secs but still holding the reset button
5. You will only release the reset button after the 3rd blink on the drive lights.
test telnet by going to the dos prompt.
Click start run, cmd,.
Type telnet ip address of your Readynas.
you can also use a 3rd party software like putty
NetGear ReadyNAS Duo RND2150  NAS server (S6819023) Network Storage Server Logo
how do i reset a 1231 to factory defaults
Unplug the AP then hold in the mode button (use a paper clip or pen tip). While still holding the button down plug the device back in and wait for the light(s) to go steady red. If your AP has a console port you should be good to go..if you have to telnet or use the GUI then the set your computer to 10.0.0.X and create an Adhoc network to gain access to the CLI/GUI.
Jul 26, 2010 | Cisco 2106 (AIR-WLC2106-K9)
I have a Netgear rnd2110 with 2 1TB disks - when copy large amounts of data to NAS drive - the system crashes with a "blue screen"
Hi, Please upgrade the RAIDar Software for NAS. You may download the same from the below link:
http://www.readynas.com/?cat=41
If the issue persists then please log a compalint with official NETGEAR support site at my.netgear.com
Regrds
Anand
Jan 05, 2010 | NetGear READYNAS DUO RND2110 1000 GB...
lanier ld122 503 service unavailable
This can occur if the Web services has been turned off in either the Web Image Monitor or from a telnet command for this device.
To check the status of these services you will need to telnet into the device.
1. From a command prompt type : telnet then the IP Address of the device
2. Telnet will respond back with a request for a login and then a password. Enter the login and password. The login and password used for Telnet are the same credentials that are used to log into the device’s Web Image Monitor (WIM).
3. Type in show at the msh> command prompt.
This will output many lines of information. The information you are concerned with is under the TCP/IP-Mode heading. You may need to scroll up in the command prompt window to see these services. The device’s services will be shown followed by their status. The ‘show’ command will show if the services are enabled (UP) or Disabled (Down).
4. If Web shows a down status, at the command prompt msh> type in set web up.
5. At the command prompt msh> type in logout
6. To make your changes Active you must type yes when prompted to "save configuration data"
Note: Always check with your system administrator before making any changes on a network device.
Aug 19, 2008 | Ricoh Office Equipment & Supplies
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
6,005 people viewed this tip
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
