Tip & How-To about Computers & Internet
Cannot access 192.168.1.1 page of a router
If you are trying to get into the router page and you cannnot access it.
Most routers uses 192.168.1.1 but some uses different address so make sure to follow the steps below just to make sure that you are typing the correct number.
1. Check first your computers default gateway.
Click start
RUn
On the run box type CMD.
It will open the command prompt or the DOS prompt.
On the blinking cursor, type "ipconfig"
Then press enter. take note of the default gateway.
2. Once you g ot the default gateway. Open your internet browser and enter the default gateway numbe ron the address bar, and then press enter.
Computers & Internet Logo
i can access the router's set up page. when i type in 192.168.2.1, it's giving me a "page not displayed" i tried turning off the firewall but i still couldn't access the router's set up page
Make sure you dont use "http://www" before the I.P. address. If that is not it then try using a different browser, or verifying the connectivity of your router to your network.
May 16, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
I am trying to connect to 192.168.0.1 but I can't get to the webpage. If I get there, I enter the correct username and password required to access the site but I still can't get in.
Hi Friend,
You need to reset the router to its factory default settings. Please follow the steps:
1.Turn the power of the router ON.
2.At the back of the router there is a small Red/black button.
3.Push and hold that button for 30 seconds.
4.Release that button and turn off the router for 30 seconds.
5.Turn it on and try to open the router page (192.168.0.1)
If the issue still persist then reset it in different manner:
1.Turn on the router
2.Push and hold the reset button for 10 seconds and then release it. Turn off for 10 seconds and turn it on
Follow the step 2 for three times (make sure the time duration is same for all three instances).
Now you will be able to open the router page.
Regards
Chiranjeet
May 22, 2010 | NetGear WNR2000 Wireless Router
how do i log into router
You need to access to the router page and find the WPA-PSK page. Set the password at this page and it is safe. You need to check back the user manual to access the router because different router have different IP address to access it. Normally is 192.168.1.1 or 192.168.1.254. You can try it
May 14, 2010 | Computers & Internet
entered the wrong ip address
Different manufacturers have differing setup so without the details of the make and model of the router in question it a little hard to help.
Most routers will have the ability for you to reset it to factory default by a button or such on the unit itself - refer to the install documentation that you got with the modem - if you dont have it you may need to aska friend to borrow their PC and access the manufactures support pages for help.
Jul 13, 2009 | Computers & Internet
Acessing the router
Ok i know what you are doing. You have to run a cable from the first router out of one port to the access point labeled internet. But make sure you connect your access point to your computer first and set it up in the router setup page. I sell and use belkin myself and if you need any futher questions let me know
Feb 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
344 people viewed this tip
David Payne
David Payne
