Tip & How-To about NetGear WGR614 Wireless Router
How to get the wireless security on WGR614 Netgear Router
Go to a computer that is directly connected to your router or you can connect your computer straight to the router using an ethernet cable on one of the LAN ports and follow the steps below.
1. Open internet browser
2. on the address bar , type http://routerlogin.com
Once you press enter , you will a box and it will prompt you to type your username and password.
The default password is password and username is admin.
3. Click on wireless settings and look for the wireless security options.
Take note of the passphrase or the wep key. If you only see dots, you can just change it and assign your own security ( make is 10 digits number and letters only )
If you change your security ,dont forget to click on save settings or apply down on the v ery bottom of the page.
NetGear WGR614 Wireless Router Logo
no ethernet connection on my computer thats hooked up directly to the 2wire router. how do i acquire ethernet connection?
My guess is that the 2wire router has a DTE plug and a DCE plug. The DTE plug is meant to plug in to your DSL modem, while the other plugs are meant to plug into computers.
If you move the plug, it might work, assuming you have an upstream and downstream connection on the router.
Failing that:
Make sure the cable is an ethernet cable and not a phone cable,
Make sure the wires are run straight through. If it is a crossover cable, it might be meant to connect a DTE to a DTE without a hub, and it won't connect a computer to a router port.
Try a different cable.
Try a different computer (borrow one, etc.)
Jan 18, 2010 | 2wire 2700HG-B Router (2700HGB)
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
still not connected
vhevk your ethernet cable wire.
if u connect router to swithc then use straight cable.
if u use router to computer use cross cable.
Jan 10, 2009 | Linksys Wireless-G Broadband Router
configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
2,420 people viewed this tip
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
