Tip & How-To about Computers & Internet
WHY DOES OUTLOOK EXPRESS INSIST ON COMPACTING FOLDERS WHEN WE CLOSE IT ?
OE has a long and troubled history with compacting folders. In the most current version, OE compacts all folders automatically after you open and close the program 100 times. Compacting folders is absolutely essential for maintaining your files in good working order. Therefore,
Do not interrupt the process once it has begun
It is best not to use your computer at all until the process is complete, which can take a few minutes.
Under no circumstances must you ever use Task Manager to kill the msimn.exe process, or put your computer on Standby, or turn off the power, or use a memory-intensive program while compaction is occurring. Any of those can cause destruction of your files and the loss of your messages.
If you don't like waiting for that 100th closing, you can compact all folders manually at any time. For best results always use this procedure.
1: On the File menu, click Work Offline so that no new messages will be arriving
2: In the Folder list, click on Outlook Express so that no e-mail or news folder is open.
3: Close the Folder list by clicking the X in the upper right-hand corner of the list panel. Alternatively you can click Layout on the View menu, and then clear the checkbox for "Folder List”.
4: On the File menu, point to Folder, and then click Compact All Folders. Do not use your computer until the process is complete, which might take several minutes.
5: If an error occurs, close Outlook Express, re-open it, and begin the process again from the top. If the same error occurs again, close Outlook Express, restart your computer (or log off and then log on again), open Outlook Express and then begin the whole process again.
Unfortunately that does not reset the internal counter to zero, so OE will still compact after the 100th closing You can edit the registry manually to reset the counter, or you can use OE TOOL to compact all folders and reset the counter at the same time. To reset it manually
1: Close Outlook Express and all message windows.
2: Click Start, click Run and type without quotes "regedit".
3: Navigate to this key
HKEY_CURRENT_USER\Identities\{GUID}\Software\Microsoft\Outlook Express\5.0
where GUID is the long number used for your Identity
4: In the right-hand pane, double-click "Compact Check Count", then change the value to zero(0).
Computers & Internet Logo
outlook express after being used so many times has to take a break and compress every thing on it ,I dont like it because it happens every time I am in a hurry and I have to sit and wait for 10 minutes or so I need to diable this feature
No you do not want to disable this feature if you want OE to run properly. It is very important for you to allow OE to compact messages in order to keep OE running smoothly. If you always say yes and allow it, then it will ask you very rarely to do this. In fact OE only asks to compact messages every 100 times you open and close the program. So open OE in the morning and leave it open all day. That way you will only need to compact messages every 100 days. Say yes when it asks and walk away, and do something else until it is finished. Under no circumstances should you say no, interrupt the process, put the computer to sleep, or run another program while it is compacting messages. Let is do it's thing and OE will run as it should.
Mar 12, 2010 | Computers & Internet
Outlook Express ''compress'' message -- but I don't use OE
No. Much easier:
Start Outlook Express.
Click File.
Click Folder.
Click Compact All Folders.
Close Outlook Express.
Nov 06, 2009 | Microsoft Outlook Express
How to disable Outlook Express 6 Compact message prompt
Unfortunately, there is no easy way to disable this. The best you can do is delay the messages, or avoid them altogether. I have listed both methods below, and would suggest number 1 over number 2:
Method #1 - In Outlook Express, click on Tools>>Options>>Maintenance. Click on the Cleanup Now button, and then Compact. Doing this regularly will keep you from getting the messages.
Method #2 -
  • Open the registry (click on Start, Run, type Regedit and click Enter).
  • Browse to HKEY_CURRENT_USERIdentitiesyour identitySoftwareMicrosoftOutlook Express.0.
  • Look for the registry value titled Compact Check Count. This typically has a value of between 1 and 5, which means Outlook Express will check every 1 to 5 times to see whether you need to compact. Double click on the item, and set the number to 100, so you will only see the message every 100 times you open Outlook Express.
- I offer remote control assistance as well! Please send me a note at Info@LoganComputersER.com
Oct 19, 2009 | Microsoft Outlook Express
outlook express
hi,
Error 0x800c0133 when you are retrieving email with your Outlook Express (OE) is because of currupted Inbox file.
To remedy please follow these steps:
  1. Open OE, on the left pane, right click "Local Folders", select "New Folder...", specify a name for your new folder as "Temp".
  2. If you are still able to access "Inbox", move all mails in "Inbox" to the new "Temp" folder.
  3. Go to menu "Tools" -> "Options" -> "Maintenance" tab -> "Store Folder" button. It will show the location of your Inbox file, please remember this location.
  4. Close OE, go to the location mentioned above, delete the file "inbox.dbx".
  5. Restart OE, the "Inbox" folder should be auto recreated. Move back your mails to the new "Inbox", remove the "Temp" folder.
or
Another solution
Error Number:0x800c0133
Error Number: 0x800C0133 = a corrupt Inbox.
Move any mail you wish to save to a local folder you create. Then:
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Press the Tab key to highlight the folder
location, then Ctrl+C. Close OE, then Start | Run | Ctrl+V will put the
location in the box - Click OK and you'll see the OE files. Otherwise, write
the location down and navigate to it in Windows Explorer.
In WinXP, Win2K & Win2K3 the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Windows Explorer, you must enable
Show Hidden Files and Folders under Start | Control Panel | Folder Options |
View.
With OE closed, find the DBX file for the folder in question {Inbox.dbx} and
delete it. A new one will be created automatically when you open OE.
General precautions for Outlook Express:
Do not archive mail in default OE folders. They will eventually become
corrupt. Create your own user defined folders for storing mail and move your
mail to them. Empty Deleted Items folder regularly. Keep user created
folders under 100MB, and Default folders as empty as is feasible.
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
Turn off e-mail scanning in your anti-virus program. It is a redundant layer
of protection that eats up CPUs and causes a multitude of problems such as
time-outs and account setting changes. Your up-to-date A/V program will
continue to protect you sufficiently. For more, see:
http://www.oehelp.com/OETips.aspx#3
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked.
Apr 16, 2009 | Microsoft Windows XP Home Edition
Sending Multiple emails
I had this same problem and found this solution (that worked!):
If your "Sent" file folder is overfull (it can only hold about 2G), OE can't file the sent message so it retains it in the "Out" mailbox. To see the size of the files in your "Sent" folder, go to your Outlook Express "Store" folder (in OE click on "Tools/Maintenance/Store Folder" then copy the information that shows where this file is located; then go to "Start/Run" and paste this information into the "Run" window; this will take you to your "Store" folder). Right-click on the file folder titled "Sent Items.dbx." It will show you the file size.
If you have too much information stored in this file folder, go back to your OE view and either delete some files from your "Sent" file folder or move them to a new folder. However, you must then "Compact All Files" (Click on "File/Folder/Compact All") in order to actually clear the space in the folder.
This should do it!
Dec 27, 2008 | Microsoft Outlook Express
190 people viewed this tip
David Payne
David Payne
