Tip & How-To about Computers & Internet
How to save a word 2007 document to be compatible with Word 97-2003
If you want to save a document to be compatible to open in word 97-2003 you cannot simply automatically save the document because it will save as a .docx. Therefore you cannot click on the disk icon at the top to save your document.
1: Go to the at the top left corner
2: Choose Save As. Another menu will appear
3: Choose Word 97-2003 Document from the list
4: Choose where to save your file.
5: After the file has been saved as a .doc you can now just press save instead of save as. You can also press on the save symbol (a floppy disk) to automatically save the file now.
Yes you can but you must download a compatibility pack from Microsoft. This will enable you to open Word 2007, PowerPoint 2007, and more in your Office 2003 program. You can also download the free Open office program. It will open .docx files already. Go to the Microsoft website to download Word viewer
And you will also need Microsoft Office Compatibility Pack for Word, Excel, and PowerPoint 2007 File Formats.
Computers & Internet Logo
i can't find my auto saved document
Step 1:
What sort of document IE: word , excell , office ......
Microsoft Word's AutoRecover feature periodically saves your document while you're working in it, even if you forget to save it manually. If you close the document accidentally, Word closes improperly or you unthinkingly write over a document or change something important, this function can save you from losing all your work. Although Word doesn't AutoSave constantly, it might have automatically saved your lost document more recently than you manually saved it. Word 2010 makes this rescue process even easier than earlier versions of Word; it stores all recently AutoSaved versions of your documents under the "File" tab.
Open the document for which you lost information. For example, perhaps you were working in a document that you had previously saved, but then Word closed and you lost your most recent work. Click the "File" tab. Click on the most recently AutoSaved version of the document under the Versions heading, next to the "Manage Versions" icon. An Untitled, Unsaved Document b> Open Microsoft Word. Even if you never saved the document, and you can't find the file on your computer because you never gave it a name, Word might have saved a version of it. Click the "File" tab. Click "Recent" on the left column of the File screen. Click the "Manage Versions" icon at the bottom of the middle column. On the drop-down menu, click "Recover Unsaved Documents." Word presents an Open dialog box, taking you directly to the Unsaved Files folder that Word automatically created. Click on the document that you want to open, then click "Open" at the bottom of the dialog box. Click the "Save As" button on the yellow bar that appears above the document, below the Ribbon; in the pop-up menu, give your document a name, choose its storage location on your computer and click "Save."
http://office.microsoft.com/en-us/word-help/automatically-save-and-recover-office-files-HP010354296.aspx?CTT=1
Mar 10, 2013 | Microsoft Office Professional 2007 Full...
How to convert scanning documents to MS-words
You are going to want to find any OCR software that works for your printer. OCR is 'Optical Character Recognition'. It will take the scan and convert it into a text document, which is either already compatible for MS Word, or easily converted itself.
Feb 24, 2011 | Office Equipment & Supplies
how to save office 2007 document in to a formate which will open in windows 2003
Hello and Welcome to FixYa!
Its simple just follow the steps;
  • When you are done with your document, Click the Round Office Button on the top let corner.
  • Just Mouse Hover on Save As
  • Another Dialog will slide
  • Click Word 97-2003 Document, if it is MS Word, or accordingly if its some other suite.
Now, if the case is that you have a document and don't have office 2003 instead of 2007 and want to open it up on that, simply download the Microsoft Office compatibility pack from here.
I hope I have covered your query efficiently. If you are having any questions, do ask.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 12, 2010 | Microsoft Computers & Internet
in which we can open .docx files
You can open docx extension files only with MS Office 2007. If you wish to open it in earlier versions you have to save it again in compatible mode. Click on File (top left most corner with the logo), Save As, Word 97-2003 Document. Just using Save option will save your document as "docx" and not "doc" document.
Aug 30, 2009 | Microsoft Windows XP Home Edition
how to open ms office file in different version
you need to open the file on the same version then save it again but on the version that you need, cause an older version could not open a newer, on the newest you have the option to save files at any version that you need
Jul 28, 2009 | Microsoft Computers & Internet
129 people viewed this tip
David Payne
David Payne
