Tip & How-To about Video Game Consoles & Games
The hard disk's file system is corrupted and will be restored. PS3
Hi, should sort your problem:
"The hard disk's file system is corrupted and will be restored"??
Here's what to do - as instructed by Sony UK (Tel: 0844 736 0595):
If you've tried `restoring` and it continues to reset/repeat to the same message:
Turn the console off by holding/pressing the power button down until you hear three spaced out beeps (before powering down);
Then hold in the power button again until you eventually hear a first and second beep - followed by a quick double beep, then take your finger off the button;
This should bring up a six option menu, such as `System Restore` etc;
Select `System Restore` and follow the instructions;
If in the event it repeats your first problem, i.e. repeating the same message, then repeat the above process to get back to the six options, although this time select `System Reset` or similar;
This will sort your problem although you will probably lose saved game data (if not backed up on a memory stick or something prior to your problem).
If you play Modern Warfare 2 online, then your data will be saved on the Sony Server anyhow and won't be lost.
When carrying out the above actions, the loading bar can be a bit slow at times. This is due to repairing the corrupted data etc on your hard-drive.
This worked 100% for me and I've no doubts will also help you.
Any problems please ensure you contact Sony on the number above.
Good Luck!!
Video Game Consoles & Games Logo
after laoding uncharted, cannot start the game by pressing x, nothing happens. I cannot remove the game from memory either
Hi, this may also sort your problem:
Good Luck!!
Jun 28, 2010 | Sony Uncharted: Drake's Fortune
what do i do if my ps3 shows a yellow light when i try to turn it on then shuts off
Good Luck!!
Jun 23, 2010 | Video Game Consoles & Games
able to play online for twenty mins approx before playstation crashes. only happening with codmw2 and codwaw. plays fine for killzone 2 and others
Good Luck!!
Jun 22, 2010 | Activision Call of Duty 4 Modern Warfare...
347 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
