Tip & How-To about Televison & Video
Should you repair or replace your TV?
Your TV just broke and your warranty has expired. What do you do? Should you repair it or replace it?
The overall rule of thumb, as is the case with any product, is to decline the repair if the estimate is quoted at more than three quarters the price of a new one. Remember that you can get a cheap TV or a really expensive Plasma TV (which are very expensive to repair sometimes due to the cost of parts alone). Whatever the product, you want to make sure your warranty covers the worth of the TV and extends for as long as you plan on keeping that set. If it's easily replaceable then replace, but for the big plasma and LED, really get that extended warranty! If you decided that your best option is to have it repaired, we will give you the most reasonale rates and the best service, including our 90 day warranty which we honor immediately if you have any problems - call Beach TV Repair at (772) 579-3116 or go
http://beachtvrepair.com/Contact.html to repair your TVs and electronics.
We have been in the consumer electronic repair business since 1987 but only in the last few years have we noticed that we are being asked this one question now several times a day, “Should I fix it or buy a new one?” With the advent of cheap home electronics, VCRs, TV sets, stereos, and now even printers, fax machines and microwave ovens, people want to know what to do when their equipment breaks. To fix or not to fix, that is the question? Their dilemma is only compounded by the prevalence of cheap replacements on the market. Well, at a time when we are being asked to separate our garbage for recycling, why are manufacturers urging us to just throw away that old TV monitor or VCR -- not recycle it but dump it in the nearest landfill? Just throw it away, even though it is full of toxic material, including lead, and other harmful stuff? Are the manufacturers actually urging us to just dump it, even though special precautions are now made (at huge expense) to get lead paint off of a house and have it carefully dumped in special toxic control sites? Not to mention there is now an added mandatory toxic fee charged on new TVs and monitors.
Besides the toxic issues, just consider for a moment all of the wasted energy and resources that go into making any of these products. Metals, plastics, IC chips, PC boards -- all made using our resources and energy. Not to mention the Styrofoam, cardboard, and fuel necessary to ship it, usually from China. All to deliver you a poorly made product that now lasts only one or two years, and all too often, only six months. Then, you, as a consumer, are given the privilege to drive down to your local store and start all over again. Wasting more resources to acquire another product that may not last as long as the one you just tossed. The quality of new products has been dropping for over 10 years now. Most products today only last 2 years or less before needing repair compared to ten years for products made a decade ago. When people discover this, they often mention the TV or VCR in the bedroom that lasted 15 years. This is because some of the best quality products were made in the 1980s.In the 1990s, as Wall Street thinking started driving the economy, quality went out the window. Welcome to the New World economy, driven by “the bottom line” to deliver you a poor quality item so some Wall Street stockholder can have a higher dividend on his investment.
About 20% of all TVs and stereos just need to have their circuit boards properly soldered. The reason they come un-soldered is the manufacturers are now making the circuit boards by putting parts on both sides of the circuit board so that they will not have to drill as many holes. Because of this, they can no longer dip the circuit board in solder as they used to do or they will destroy the parts they put on the bottom. Instead, they are sprinkling the board with a poor quality solder dust and melting it with a type of blow dryer device. The connections come un-soldered in just 2 years instead of lasting 10 or more years like they used to do. This is all done in order to bring you that cheap TV, although this same poor way of soldering is done on the more expensive models, too, so they don’t last too much longer than the cheap ones. This problem is readily repairable by soldering the broken connections by hand with the proper solder; the way circuit boards should be soldered. When done properly, your product can easily last many times longer than when it first left the factory. The second most common defect is, the manufacturers often put in a few undersized or low quality key parts, which promptly fail. Once these flawed parts are replaced with a quality part, your machine can last longer the second time around, sometimes by many years. We are actually in the business of re-manufacturing electronic equipment when you get down to it. And consider this, another 30% of all broken VCRs, CD players, DVDs, fax machines and printers are not broken at all but just need a good cleaning and nothing more. What is the solution to all this? Don’t give up on your equipment so quickly. Have it checked by a competent repair person first. Spare our environment from more toxic waste. And, as most electronic manufacturers are now foreign-owned; taking your money out of the country, investing in a repair is good for our “local” economy. Save yourself some money, too. It is often the cheaper option because our American ingenuity can make it better and last longer, saving you money and energy in the long run.
***PLEASE NOTE CAREFULLY*** TV sets contain dangerously high voltages (more than 30,000 Volts) and even "quick fixes" should not be handled lightly. Do not touch anything inside the back of the Tv IF you take off the back of the set (we don’t recommend doing that!) When making any repairs, wear safety glasses and work gloves at all times.
Televison & Video Logo
i brought samsung tv before 1 year date on 6/11/2009 and before warrenty expire i make complain for voice humming and colour patch but your technical engineer come on 4/11/2010 and he didnt do anything for problem solutution,and go away. now my warrenty expire what i do. my problem is continue. please possible help me, my name is sanjay patel and cont no is -9427679752, add-shivam soc,sujatpuraroad,kadi-382715
I don't know what your local ruling is regarding warranty repairs but in Europe, if a fault is reported before the warranty period has expired and the fault is not rectified for a period of at least 3 months, the warranty for that fault continues until the fault is rectified.
I should contact Samsung now and explain the situation to them. Write it all down and don't delay!
Hope you get success.
Nov 09, 2010 | Samsung Televison & Video
my vizio 32" tv won't turn on, only the red led light does. My warranty expired one week before the tv stopped working. can you please help me
I would try real hard to get it repair under warranty, they may bend the rule sinc it is only one week over warranty. Right now the 5vdc standby power supply is working. Typical repair for LCD TV is $200 and up plus parts. If they refuse, I would not buy another VIZIO.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 21, 2010 | Vizio VW32L 32 in. LCD HDTV
TV UNDER WARRANTY & NO RESPONSE FROM DEALER JAN.6,2009
All too often, extended and third party warranties are not honored as they should be. Some are even totally worthless. The general plan of a lot of third-party warranties is to hold the customer off until the warranty expires, and then deny it. If this was an extended warranty through the Rex store, then consider talking to a lawyer as soon as possible. One letter from an attorney may be all it takes. Or even the threat of going to an attorney is enough some times. It is a legally binding agreement that expires, so once it is up, they will almost certainly deny your claim.
Almost all extended warranties have a time frame for repair, and more specifically replacement! If they cannot repair the TV within a certain amount of time, then they should replace it.
I hope this helps you...
Jan 06, 2009 | Televison & Video
tv won't come on
The TV does not turn on and stays in standby because it is gone in protect mode, this happens when the TV main chipset detects that there is an internal problem, sugh as a wrong voltage, a capacitor that had blown, a defective integrated circuit, or any other internal fault.
Try leaving the TV unplugged a little longer, to drain power completely, just in case the protection circuit is stuck in error mode.
If the TV does not restart after leaving it unplugged overnight, that means that there is an internal fault, and something inside TV must be replaced or re-soldered (bad joint).
You can call a technician using the phone number printed on the owner manual, or checking on Hitachi website, or letting us know your location.
Calling the factory or the seller you can also ask the price for a warranty extension.
A warranty extension will cover any repair for the next year in case the original warranty is expired.
A warranty extension is oten less expensive than a single repair job.
Nov 05, 2008 | Televison & Video
sanyo hdtv
Just as when the warranty expired. Ouch! Granting that the power cord is connected properly, the culprit here is a Power Supply Board gone bad. It's not a simple 'blown fuse' case. Repair can go upwards of $400. What I can recommend is to verify Sanyo's warranty terms. If it is in fact two years, you can call them (being polite helps) and request for a concession repair. It's like a courtesy one-time freebie repair for you. Build your case from the fact that the unit broke just as the warranty expired. Goodluck!
Jun 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
239 people viewed this tip
Top Televison & Video Experts
