Tip & How-To about Refrigerators
Ice makers that don't deliver..
Whrilpool ice maker's ( bin on the door model's) makes ice but will not dispense.. ans .. remove the ice bin and rinse with warm water / also clean the delivery shute / make sure all parts are dry .. then the majic . SPRAY THE SHUTE AND BOTTOM OF BIN BOTH SIDES WITH ( PAM) NO BUTTER ) .. THIS SHOULD CONTROL THE PROBLEM . do this on a reg basis and end of problem . you can also use a food grade silcone . .. hope this tip helps **** ..
Refrigerators Logo
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give me instructions on how to install it. Thanks in advance.
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Door dispenser will not dispense the ice.
you and many others have this problem . ( tip remove bin and rinse out with warm water dry it well and the door area also then the majic ... spray the dispenser with ( pam ) without the butter . clean and slick . this should help . mm
Jul 02, 2010 | Whirlpool ED2FHEXN Side by Side...
ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool side by side GS6NBEXRS01
If nothing is blocking ager .. sounds like motor bad or something binding it up. If you took in out and cleaned all ice out and still dont work with no ice.. sounds like motor ..if it hums power is to motor
Aug 28, 2007 | Whirlpool GS6NBEXR Side by Side...
218 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
