Tip & How-To about Cell Phones
Help! I've dropped my phone in the water!
Relax, it's going to be ok! If you have insurance on your phone, they will charge you extra to replace a water damaged phone (Asurion via Verizon charges $50!)
First things first, a little explanation. Inside you're phone is a circuit board full of electronic components, these boards don't like moisture because it allows the current from the battery to take alternate paths across the board, this can damage components.
So, your first step is to act fast! take that battery out before damage occurs! it can take anywhere from a second to an hour for the damage to occur, you can never tell because it depends on the phone, the quality of the internal components, where exactly the water got, etc.
Next, when water dries, it leaves behind residue, this may also be conductive and damage components.
The next step is a drastic measure, so it's recommended to let your phone dry with the battery out for 24 hours, and then see if it works, being careful because if it doesn't function properly right away you need to pull the battery again quickly.
If that fails get a glass the will hold your phone, and fill it with 90% or higher isopropyl alcohol, put your phone in it, and shake out the bubbles, this will clean your phone inside. When the bubbles stop take your phone out and again let it dry without the battery for 24 hours.
WARNING: putting your phone in alcohol is a last resort only and is not guaranteed to work, in most cases this will fix your water-damaged phone, but not all. Also the alcohol may make the inside of your screen cover hazy on some phones (Blackberry 8330 for sure). This is due to the material they used for the screen cover, the alcohol actually ate some of the material on the cover. The phone is still usable but the haze is just annoying. If this happens to you google search for directions to replace the screen for your phone, follow them to get the screen cover off and buff out the inside of the screen cover lightly, the haze will come out eventually.
So there you have it, good luck!
Cell Phones Logo
Iphone stopped working less than year after got it from Asurion. Asurion sent replacement and we sent broken phone back. They put $479 charge on bill for damages.How can I fight this?
If you bought by Paypal they may take up this dispute for you. They fought 2 cases for me and got my money back.
Log into your account and look for dispute
Dec 03, 2016 | Apple iPhone Cell Phones
my screen wont turn on but the keypad will for a few minutes its
its toast- sorry for your loss- only a matter of time before the rest of the circuits go with the screen (Asurion guy here- its insured if you got the insurance for it)
Aug 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Verizon Voyager will not chage or work on battery, fine on AC
Sounds like the battery connections may be corroded, try gently cleaning them with a pencil eraser. Clean the connections on the battery and in the phone. Water damage is indicated by a red indicator in the phone. if it is red it indicates water damage which is probably why they will not replace it. If you have insurance on the phone that may be an option for you.
Apr 21, 2009 | LG VOYAGER VX10000 Cellular Phone
AudioVox CDM 8910 Charger Port Broken
hi plz dont try to do it yourself == go to a local phone repair store and in your presence tell the technician to do it == this will not charge you much and the rick factor will be nill Good luck
Apr 27, 2007 | Audiovox CDM8910WW
190 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
