Tip & How-To about Computers & Internet
Locate your Corsur In Windows 7
To turn on the Cursor feature in Windows 7, go to your desktop and RIGHT CLICK on the DESKTOP displayed and in the drop down window CLICK on PERSONALIZE and when the next window opens CLICK on CHANGE MOUSE POINTER. Then on the next window select POINTER OPTIONS tab. Next put a check mark in SHOW LOCATION OF POINTER and click OK.
Now when you press CTL, a circle will flash briefly to show you where the cursor is.
Hope this will be of some help in finding your cursor. Bud
Computers & Internet Logo
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
How to change wallpaper in Windows 7 The Windows 7 Starter edition does not include the Personalization features such as the change desktop background option. 1. Download the Oceanis Change Background Windows 7 ZIP link: http://www.sevenforums.com/tutorials/47294-desktop-background-change-windows-7-starter.html Open the ZIP file and extract the Oceanis_Change_Background_W7.exe file, then run it to install it. NOTE: Restarting the computer will be required to finish installing this program. 2.When your computer restarts, you will see this as your desktop background. Click on the Oceanis Change Background Windows 7 shortcut to change your desktop background. (see screenshot below) 3. Browse to the images that you want to use and select one, or more to have a desktop slideshow. Select the Picture position for how you want the images displayed, and any desktop slideshow settings if you selected more than one image. (see screenshots below) NOTE: These options are just like the default ones in the other editions of Windows 7 here that are now being allowed by this program by Oceanis for the Windows 7 Starter edition. 4. When done, click on Save changes. (see screenshots above) Default Windows 7 Desktop Background 1. Right click on a empty space on the desktop and click on Personalize. (See screenshot below) 2. Click on the Desktop Background link at the bottom of the window. (See screenshot below) NOTE: The name in gray under Desktop Background is the current desktop background file name. 3. Select a Picture Location - A) Click on the drop down arrow menu to select from the list of available picture folder locations, or click on the Browse button to navigate to the picture folder location. (See screenshot below step 7) NOTE: To use another regional wallpaper, see the yellow TIP box at the top of the tutorial. B) Select the picture folder and click on Select Folder. 4. Select a Desktop Background - A) Right click on an available picture, or click (check) on the box in the upper left corner of the picture, to select it. (See screenshot below step 7) NOTE: You can continue to right click on the images to see it previewed on your desktop until you decide which one you like best. 5. Select the Picture Position - A) Click on the drop down arrow menu, and click on the picture position you want for the desktop background. (See bottom of screenshot below step 7) 6. For a Desktop SlideShow - A) For how, see: How to Create a Desktop Slideshow in Windows 7 link: http://tinyurl.com/yaqll2x 7. Click on OK to apply the changes. (See screenshot below) 8. Close the Personalize window when done. (See screenshot below step 2)
Feb 02, 2010 | Computers & Internet
how do you change the font size on the computer?
@mychelemyche
Try the following:
For Windows XP
1. On the Desktop, right click on an empty space and select Properties.
2. A Display Properties window will open, click on the Appearance tab and on the Font size drop-down, choose Large Fonts or Extra Large and click Apply.
For Windows Vista.
1. On the Desktop, right click on an empty space and select Personalize.
2. Click on Adjust Font Size (DPI)
3. Choose Large Scale (120 DPI) or Custom DPI (if you want bigger font)
For Windows 7
1. On the Desktop, right click on an empty space and select Personalize, then click on Display.
2. Choose Medium or Set Custom Text Size (DPI) if you want bigger font.
Sep 07, 2011 | Computers & Internet
what is resolution setting
You can find your resolution setting in the display options. In Windows XP: Right click on a blank area (no icons) on the desktop and go to Properties. Click the "Advanced" tab and your resolution will be on a slider about halfway down the window.
In Windows 7: Right click any area on the desktop (just like XP), but then click on "Display Resolution". Your resolution will be in a drop-down box in the middle of the window.
Another way to find it is to go to the control panel and open the Display Properties dialog in there, then search for it that way (using XP directions).
Aug 29, 2011 | Computers & Internet
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is only when I turn on laptop I dont see anything just black screen.I must always conect and disconnect external monitor to work properly. Problem is on WINXP and WIN 7 Best regards Dejan
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
164 people viewed this tip
David Payne
David Payne
