Tip & How-To about Computers & Internet
Problems when dropping a device with an optical reader
There are three potential problems that I can see if you have dropped your optical device:
1. Most often, the device is damaged or worn out so that the disc 'brake' will not disengage or the door isn't recognized as closed. The 'brake' is an eraser-like device under the CD door that stops the disc when the console is turned off.
2. The other problem could be the console is not detecting that the CD door is closed and thus will not spin up the disc to start.
3. The laser is worn out or shattered.
At any rate, the best thing to do is take the device in to a local technician for servicing. The techs can replace any of the parts for the cost plus labor. A great place in the Vegas area, for example, is at http://www.vegasgamerepair.com/
Good luck to you!
Computers & Internet Logo
2003 saturn vue
Perhaps it's still tired from the previous night and hasn't had appropriate levels of caffeination. Check voltage at the fuse circuit and all appropriate points along the circuit path. Check for both blown AND simple worn fuses....which won't carry the full current and could potentially cause a noticeable drop in voltage leading to the sluggishness. Similarly, make sure there are no broken or worn wires or connectors along the circuit path.
But before any time is spent delving into potential electrtical sources for the poorly performing moon roor, thoroughly clean out carefully examine the track and areas the roof moves from A (close) to B (open) for obstructions like leaves/debris, dents or small buckles or flares in the body, damaged seals and worn rubber gaskets.....basically anything that could cause an obstruction or slow the open/closing action......
Finally, if nothing comes of these first 2, carefully test the motor/drivers that power the movement of the moon roof.
And lubricate, lubricate.......LUBRICATE!!!!
Jul 06, 2014 | Vehicle Parts & Accessories
The first three speeds you get nothing....it only operates on high #4 speed and it is a little bit noisy
IF ITS AUTOMATIC TRANSMISSION. THROTTLE VALVE CABLE NEED ADJUSTMENT OR COULD BE THE GOVERNOR PROBLEMS LIKE VALVE STUCK GOVERNOR WEIGHTS BINDING. GOVERNOR DRIVEN GEAR DAMAGED OR.BURNED DIRECT CLUTCH PLATES.THE 1-2 3-4 SHIFT VALVES STUCK IN VALVE BODY. IF IT MANUAL TRANSMISSION SHIFT LINKAGE OR SHIFT FORK OUT OF ADJUSTMENT OR WORN DAMAGED OR I- 2- 3 GEARS AND BEARINGS WORN OUT.
Jul 09, 2010 | Cars & Trucks
XP installation hangs on MSI 945GCM5 diring installation
Too many possibilities. If you have any further information or error messages, please post them.
I would try the basics first.
1.Check your install CD for scratches or damage.
2.Test your RAM for potential problems. (memtest 86)
3.If possible swap your installation optical drive for a different one.
4. Remove all add-in cards (extra USB cards, modem, network cards, etc.) from the system
5. Try to install using a single RAM module.
6.test your hard drive for potential problems. (Most hard drives have a unique diagnostic tool, but DFT works for Hitachi drives as well as others)
Jul 15, 2010 | MSI 945GCM5 Motherboard
dropped PS2 and now it will not read or spin cd
butter,
There are two potential problems that I can see:
1. Most often, the PS2 is damaged or worn out so that the disc 'brake' will not disengage or the door isn't recognized as closed. The 'brake' is an eraser like device under the CD door that stops the disc when the console is turned off.
At any rate, the best thing to do is take it in to a local technician and have your PS2 serviced.
Jul 02, 2010 | Sony PlayStation 2 (PS2) Console
747 people viewed this tip
David Payne
David Payne
