Tip & How-To about Computers & Internet
How to fix a DLL error on your computer
A common question I get asked all the time is how do I fix DLL errors? In almost all cases DLL errors are caused by a corrupt system registry. You need to clean and repair your Windows registry to correct these errors. While this can be done manually if you are an experienced computer technician it is usually not recommended.
Altering the Windows registry can be very complicated. Alter or delete the wrong file in your computer may not start up again or become unusable. There is much safer way. You can download and run software that is made for the job and safe to use. Since Windows does not come with anything for registry cleaning and repair you will have to download one from a third-party. The ones recommended on our main page are all safe and thoroughly tested.
So if you have DLL errors on your PC and need to repair them just follow the simple procedure. Download one of the registry repair programs from our main page, install it and run a scan on your computer, when it has completed and detected all the errors click the fix errors button. You may have to restart your computer, however after that all your DLL errors should be completely gone your PC running as smoothly as when you first bought it.
There are some free program for registry cleaning but they’re not recommended. Most of them don’t do a thorough job therefore they miss a lot of errors. Then there are some that are poorly written and may damage your computer deleting files your PC needs making it worse off than it was before.
DLL errors are caused by corrupt registry entries. You can get these from poorly written software, installing or uninstalling software, viruses or spyware, improper shutdowns and driver errors. Scanning and cleaning your registry is like giving your PC a good tuneup, most people notice an improvement in speed and performance. The registry is one of the most often overlooked systems on personal computers. Regular maintenance should be performed on it to keep your computer running smooth.
Computers & Internet Logo
i cannot start my microsoft office outlook MAPI32.DLL is corrupt
This Common Mapi32.dll Errors occurs because of a corrupt or damaged windows registry. In this case you can resolve them by using a registry scanner which is updated with all the most recent information.
Apr 19, 2011 | Microsoft Computers & Internet
I've been getting an error message: sysenv.dll missing
Hi friends,
"The file sysutil.dll is missing."
"Cannot start Metamail. A required component is missing: sysutil.dll. Please install the application again."
sysutil.dll error notifications may appear while using or installing certain programs, when Windows startup or even shutdown. sysutil.dll errors are caused by situations that lead to the removal or corruption of the sysutil.dll. In some cases, those errors could indicate mostly a registry problem, a virus or malware issue.
to Fix Sysutil.dll Errors
The sysutil.dll error message could apply to any program or system that might utilize the file on any of Microsofts operating systems including Windows XP, Windows 7, Windows Vista, and Windows 2000.
You can fix a sysutil.dll error and there are many ways to do it. A registry cleaner program can help by removing invalid sysutil.dll registry entries that might be causing the DLL error. The below utility is without a doubt the best one out there at the moment.
> Click Here http://filehippo.com/download_ccleaner/
Let me know if any further clarification is required. Hope it will help! Dont forget to rate the solution!!
Dec 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
Windows XP boot after an error, it can not find the file shfolder.dll, and is included in the Windows folder. What do I do?
http://www.fix-all-dll-errors.com/shfolder.dll/
This will fix the issue without any botheration.find that dll here :)
Dec 15, 2010 | Microsoft Computers & Internet
sir i have downloaded a game from net i installed it and tried to open but it gives a message "this application was faiiled to start because mss32.dll file is missing" plse help me to start the game
Mss32.dll Error is a common Windows error message. Mss32.dll Error is usually caused by a missing system files, wrong system settings or a corrupted registry file. Use CTRL+ALT+DEL to get the task manager, if there is anything listed with [Not Responding] end task it. Next, run a registry scan to check for registry errors & other system problems. 96% of the time this will fix the cause of the error
It is best to clean your registry in order to optimize system performance & Fix the cause of many Windows Errors.
Apr 14, 2009 | Computers & Internet
2,117 people viewed this tip
David Payne
David Payne
