Tip & How-To about Computers & Internet
How do you bypass the admin password on Windows XP
Method one: Log into an alternate account
Often many users will leave the administrator account alone and/or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
1 Reboot the computer into Safe Mode. Additional information about getting into Safe
2 When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try simply pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
3 Once you've logged into the Administrator account open Control Panel and User Accounts.
4 In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
Method Two: Using the forgotten password diskette
If you have forgotten your Windows XP password, however have created a forgotten password diskette earlier to use the diskette follow the below steps.
1 At the Windows XP login prompt when the password is entered incorrectly click the reset button in the login failed window.
2 Insert the password reset diskette into the computer and click Next.
3 If the correct diskette Windows XP will open a window prompting for the new password you wish to use. .
Method Three: Use a third party software.
Windows Password Key 8.0 is considered as the best tool to reset local administrator and user passwords on any Windows system.
Download the utility and install it then burn the software to a CD/USB drive,then insert the newly created CD/USB drive to your locked pc and reboot your computer,then press "F2" to enter your BIOS setup,following the instruction to reset your lost windows password.
See,there are many ways to help you remove windows logon password,so you don't need to worry about when you heve forgotten windows password
Computers & Internet Logo
retrieving administrator settings
Click start Control Panel.
Select "User Accounts and Family Safety," then "User Accounts."
Click "Turn User Account Control on or off."
Remove the check mark next to "Use User Account Control (UAC) to help protect your computer."
Click "OK."
Set All Accounts to Administrator
Still in the UAC section of Control Panel, select "Manage another account," and click on a user account.
Click on "Change the account type." When working with multiple accounts, some changes can only be made if you and the account holder are both logged in with "Administrator" accounts so you need to change all user accounts to "Administrator."
When you are done making changes, you can change them back to "Standard," but always leave at least one "Administrator" account.
Select the "Administrator" radio button.
Click "Change Account Type" at the bottom right.
Repeat this procedure to change each user account to "Administrator." When all user accounts have been changed, close the Control Panel.
Create a Full Administrator Account
Click "Start" (the Windows Vista icon in the lower left of your screen). In the Search box, type "cmd". Right-click on "cmd," and select "Run as Administrator." An elevated command prompt window will appear.
At the command prompt, type "net user administrator /active:yes", and press "Enter."
Choose a password and assign it to the "Administrator" account, by typing "net user administrator 'password'", where 'password' is your selected password. For instance, if your password is "abc," type "net user administrator abc". Press "Enter."
Type "exit" and press "Enter."
Log off. When you log back into your "Administrator" account, you will have full rights.
hope this helps
Sep 17, 2012 | Dell Inspiron 530s Desktop Computer...
How to Recover and Reset Password in windows 7/Vista/XP/2003/2K/NT for Free
There are many people forget their admin password, and there are many solutions for those who have been locked out by computer. Below methods for you to try: You can use the password reset disk if you ever created. If not created, You also can Log on as an administrator to reset the password. Start system, press alt+ctrl+del keys Twice when you See Windows Welcome screen and then the Login box appeared. Now type "Administrator" in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". The above methods may be a little difficult for non-technician guys even the newbie. Another method may more suitable for you to use software program. Password Genius is the best software I have ever used. You can have a try. Check it out:"www.password-genius.com/how-to/how-to-recover-my-windows-login-password.html"
Dec 30, 2009 | Computers & Internet
I DO NOT KNOW THE PASSWORD OR USERNAME FOR MY QWEST P5000Z MODEM . dONT KNOW WHERE TO START TO FIND IT OR CHANGE IT? PLEASE HELP! THANKS- AMY : )
what operating system ? and what type and brand of computer desktop laptop ?
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
hope this helps
Sep 22, 2011 | Computers & Internet
I HAVE FORGOTTEN THE PASS WORD ON THE DESK TOP ACER COMPUTER
which password ru forget os password or bious password
Jul 09, 2008 | Acer Computers & Internet
Windows XP - Cannot access user name or adminstrator name to log in
Have You Lost Your Windows Admin Password?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Apr 07, 2008 | Linksys EtherFast PrintServer Print Server
348 people viewed this tip
Ekse
Alun Cox
