Tip & How-To about Washing Machines
Code f24 on kenmore washer
Washer wouldnt start,code f24 kept popping up,i finally deciced to tackle it,got some tips on here,then removed the back panel of my machine,there was a little electrical connector wire unplugged,in plain site but only seen from the back,could not cheat and see from the front,all i did was plug it back in and put it back together and its been great ever since,hope this helps see ya
Washing Machines Logo
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have an F 24 error flashing. It is on the rinse spin cycle
The "F24" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature sensor. The temperature sensor (key#24) is located at the rear bottom of the tub. (See images below)
You can gain access to the temperature sensor by removing the rear washer panel. NOTE: Disconnect the power cord from the power source before removing the rear panel
Image 1
Image 2
Nov 28, 2010 | Kenmore HE2 Plus Front Load Washer
F24 comes on. Just won't work. I have tried turning off power.
The F24 error code indicates a problem with the water temperature sensor. The technical explanation for this code is provided in the first image below. The location of the temperature sensor is shown in the second image. The temperature sensor is Key 24. The third image provides the testing procedure for this component. To access the temperature sensor, unplug the washer and remove the back panel. Unplug the wire harness connection to the sensor and check the resistance with a volt/ohm meter. If the sensor is apparently bad, it will need to be replaced. You can order a new temperature sensor from the Sears PartsDirect website www.searspartsdirect.com . The part number is 8181705. If the thermistor tests good, you could have a water fill problem, a wire harness connection issue or a failed control board that would cause this error code. If you need more help, resubmit your question with additional details and the full model number of your washer.
  • image53469img-th.jpgView Larger
  • image53474img-th.jpgView Larger
  • image53475img-th.jpgView Larger
  • Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    f 24 error code
    f24 error code has to do with the water temp sensor,turn the washer off set the washer to cold only and start the washer for a reg. cycle this will confirm the problem,also you can check your water hoses are ok and remove the back panel to check the water pump that everything is tight,let me know how you do,mike
    Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    f24 error code
    Take off the lower panel of your washer and under this panel on the back of panel is a book which tells you what the error codes are and how to fix them or test for them. It looks like a tempature sensor code to me.
    Apr 19, 2008 | Kenmore 46462 Front Load Washer
    248 people viewed this tip
    Top Washing Machines Experts
