Tip & How-To about Computers & Internet
How to pin Device Manager to the Start menu
Device Manager is a handy Windows tool for managing and troubleshooting components and peripherals. There are several different ways to access the device manager, however each of them requires a few steps. For easier access, why not pin the Device Manager to your Start menu?
Pinning a program to your Start menu is a simple procedure -- just right click on the file name or icon and select "Pin to Start menu." However, the Device Manager is typically accessed from inside another window (usually either the System Properties screen or the Computer Management console), and you can't pin it to the Start menu from there.
In Windows Vista, you can hunt down the Device Manager using the Search bar (just type "device" or "device manager" into the Search bar) and right click it from there to pin it. In Windows XP, the process is a little more involved -- you can follow the same steps as for Vista, but XP's search feature takes much longer to find files than Vista's does, so you'll be waiting at least a minute or two. By the time the system finds the Device Manager, you could have already been done with the whole thing.
To find the Device Manager file in Windows XP, open up Windows Explorer (Start > All Programs > Accessories > Windows Explorer). Click the plus sign (+) next to My Computer, then navigate to C:, then Windows, then System32. In the System32 folder, find a file called "devmgmt.msc" -- this is the Device Manager. Right click on it and then select "Pin to Start menu."
Computers & Internet Logo
why won't my volume wont work on pavilion dv7
Step 1: Using the Troubleshooting tool in Windows 8 The Troubleshooting tool in Windows 8 can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run the Troubleshooting tool first before you manually correct problems.
To open the Troubleshooting tool:
  1. At the Start screen, type find and fix audio to open the Search charm. Figure 1: Find and fix audio search
    c04030165.jpgShow all ' Hide all [img id="doc_plus_doc_sc_6.1" src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/hpweb_1-2_plus.gif" alt="show" >
    Update the audio driver from the HP Web site
    [/a] hpweb_1-2_plus.gif
    Update the audio driver using Device Manager in Windows 8
    Step 4: Checking Device Manager to troubleshoot audio problems (Windows 8)
    If you cannot hear sound, check Device Manager to determine the state of the sound hardware.
    1. At the Start screen, type device manager to open the Search charm. Select Device Manager in the Search results. Figure 13: Device Manager
      [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c04030167.jpg" alt="Device Manager on the Search screen" title="Device Manager on the Search screen">
    2. Double-click Sound, video and game controllers .
    3. Do the following, depending on what displays:
Jul 14, 2014 | HP Pavilion dv9000z Notebook
I/O ERROR
A Device I/O Error is an error that occurs as a result of using a peripheral device such as a printer or external hard drive. I/O means an input or output error that is caused by a driver that is outdated or not yet enabled. The device driver is a necessary component for allowing your operating system to control and communicate with the peripheral device. When a Device I/O Error occurs your PC is unable to set up the software that is needed to configure the device driver and operate the peripheral unit.control panel administrive tools ,computer management ,device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/sto do this right click on the ? x ! select reinstall driver
hope this helps
Jan 13, 2011 | Computers & Internet
just reinstalled windows xp and now my creative labs soundblaster live! audio card is not detected. did all the troubleshooting in the hardware manager and it says the the device is working properly. did windows diagnostics and it could not "unmute" the card even though all of the device manager screens say the card is unmuted. ran the creative labs soundblaster live! diagnostics and it can not detect the card to diagnose the problem. what else can it try?
You could have a ghost device in the system. Remove the card and start the computer in safe mode. Look at the device manager to see if there are any sound devices detected. If so, delete them. Now install the card and let Windows detect it. You probably left the card in the machine when reinstalling the O/S. You shouldn't have any peripheral devices hooked up when doing a reinstall of Windows XP.
Sep 26, 2010 | Creative Labs Sound Blaster Live! 5.1...
Scansnap manager won't properly install on windows xp...
Problem solved. Ignore the "Windows XP approval" message & continue with the fix suggested in the troubleshooting section of the manual.
Feb 18, 2009 | Fujitsu ScanSnap S510
1,207 people viewed this tip
David Payne
David Payne
