Tip & How-To about Philips Magnavox 50ML8105D 50" HDTV DLP TV
DLP TV won't run after replacing lamp.
When the lamp on your DLP blows out or the "replace lamp" light says it's time to replace the lamp, you do, then the unit will not power on you may not have inserted the lamp fully, correctly or the interlock switch may not be closing completely on the lamp door.
For safety purposes DLP TV's have an electrical interlock where the lamp door closes. The set cannot be energized with the lamp door off or open. If you remove the lamp door you should see an arm on the door and a slot in the frame with the contact for the switch visible through it. Make sure that the arm is not broken off or damaged in any way.
With the door removed, remove the lamp assembly being careful not to touch any of the glass. If you still have the replacement instructions reread them and follow the reassembly instructions carefully.
Be certain that the lamp assembly is installed properly and seated completely on the power plug. When you are absolutely sure that it is mounted correctly, attach the lamp door making certain that the interlock is being depressed by the arm on the door.
If the unit still does not power on remove the back from the set. This generally involves removing many screws around the perimeter and should be obvious if studied for any length of time. Once the back is removed look at the interlock switch and make sure it is mounted correctly. Many times removing and reinstalling the lamp door will move the switch (if it is loose) causing the switch to not perform it's task and clear the fault for the lamp door.
If the unit appears to be mounted correctly use a DMM to check the continuity of the switch both open and closed. If the switch shows continuity when depressed it is good. Reassemble the unit and try it. If the lamp door switch was the problem you unit should now work.
If your unit still will not work I have a tip at http://www.fixya.com/support/r4606286-troubleshoot_dlp_tv which may be helpful for more advanced troubleshooting.
Thanks for using FixYa.
hardrocko
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
TV picture and sound goes off--leaving a blinking green light showing as on (power). Several times in the last week I have shut the power strip off and then on again and the TV went back on with the solid green light for power. TV is plugged into power strip due to build in unit cabinet, but that is not the issue since it has worked for several years that way and this issue has only come about in the last 2 weeks. TV unit is about 4 years old. Ideas?
If TV goes off and the led stays blinking, that is because the TV is going on protection.
Protection is a special diagnostic mode that starts when an internal fault has been detected.
If this happens erratically while you are watching TV, then parts that can commonly cause the problem are PSU board, main board or digital board, ballast board and converge board on DLP, inverter on LCD, low buffer and sustain boards on plasma.
May 14, 2009 | Televison & Video
projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Samsung 50" DLP Lamp died, new lamp will not light`
Bad news.  Mine did the same thing.  Mine is the 61", but the internals are basically the same.  I replaced the lamp and the problem was fixed.  Then after a couple days, it died again.  I replaced the ballast, to no avail.  Took it to the certified repair center and they said I needed a new DLP Light Engine.  They wanted $1250 to fix it, but I was able to order one online from partstore.com for $700 and fixed it myself.  No problems since.
Your certified repair center will charge a minimal fee to diagnose and then you can fix it yourself if you choose.
The easist fixes for the lamp problems are A) replacing the bulb and B) replacing the ballast.  Anything else, you'll want a certified tech to diagnose the problem.
Jan 17, 2009 | Samsung HLN5065W 50" Rear Projection...
3,687 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
