Tip & How-To about Computers & Internet
INSTALLING A PRINTER IN WINDOWS 7
To install a printer in window 7, you need the printer installation CD/software.
Connect the printer to your system via a USB Cable (or any other cable necessary). Power on the printer. If you use a USB cable, windows 7 will automatically detect the printer and try to install it for you. However, if windows 7 does not have the driver, you will be prompted to load the drive from CD or a file location. If you have the Driver CD, load it now or browse to the folder where the driver software is located and load the software. Follow the on screen instruction to complete the installation.
Also
From start------devices and printers ------ add a printer ------add local printer ----- use an existing port, next ----------choose the printer manufacturer and the printer model. If not on the list and you have the installation CD choose have Disk and then next. Follow the onscreen instruction to complete the installation.
You can also run the Printer driver software and follow the onscreen instruction to complete the installation.
Computers & Internet Logo
HP Deskjet 1220C Drivers for win 7 x64
Hi.
Click this link http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01874792
For instruction information for windows 7 operating system.
Read and Do that step by step instruction of HP website.
Jun 28, 2011 | HP DeskJet 1220c InkJet Printer
HP-1110 printer scanner can't be use in Windows 7 PC
Follow these steps to remove previous HP drivers, and then install the new driver.Step one: Remove previous HP drivers Follow these steps to remove the current drivers.
  1. Disconnect the USB cable from the HP product, if it is connected.
  2. Click the Windows icon (c01367376.gif ), and then click Devices and printers .
  3. Find the printer icon (c01813941.gif ) representing your HP product, right-click it, and then click Remove device .
  4. Follow the on-screen instructions to remove the driver.
  5. Repeat these steps to delete multiple instances of the same printer icon, and also for any fax icons for the product.
  6. Reboot your computer.
When your new operating system is up and running, simply connect the USB cable from the computer to the back of the HP product, and then press the Power button (c01602202.gif ) to turn it on.
Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
Feb 28, 2011 | HP LaserJet 1000 Printer
I bought the HP Deskjet 5650, but I'm not sure how to install it to my home computer.
First find the installation disk that came with your printer in the box. Install the software by placing the disk in your CDROM of your computer and then follow the instructions on the screen. when the software has finished installing, connect your printer to the computer with your USB cord and the computer will automatically do the rest.
Some operating systems already have the driver for your printer and the software is not necessary. To check and see if your computers operating system already has the necessary drivers, just connect your printer via your usb cord. Your computer will recognize the printer once the cord is connected and you will see a pop up message around the right hand corner of the monitor screen that says "new equipment detected" and the computer will do the rest.
Nov 11, 2010 | HP DeskJet 5650 InkJet Printer
cannot install hp color laserjet 2605dn printer in windows 7
Specific print driver and software information for printing in Win 7 is available for HP LaserJet, Color LaserJet and LaserJet MFP products.
This printer cannot be installed with installation disc or download.
May i know what is the error message that you get while installing.
Aug 19, 2010 | HP Laserjet 2605 Printer
usb device not recognised
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
219 people viewed this tip
David Payne
David Payne
