Tip & How-To about Plumbing
Slow shower drain fix.
This tip will show you how to fix a slow tub drain. In my experience most slow shower and tub drains are caused by hair. Usually within reach of a wire hanger. Since you probably do not have all the proper tools, you must be careful not to damage your drain line.
The trickiest part with most shower drains, is the pop up assembly.Most times the hair is caught on the pop-up components. If you have a pop-up, check with your local hardware guy to show you how it works and is assembled. On a pop-up, you'll have to take the drain plug/cap off. have the cap in up position, and get your eyes below the cap rim, you will see a small set screw, a couple turns and cap should come off, do not take set screw all the way out. If you see hair on assembly after taking assembly out, remove the hair and run some water to see how your drain is working. If that does not fix your slow drain, you should stop there and call a plumber, because that means you blockage is further down the line then you'll be able to reach.
If you have no pop-up assembly. Untwist hanger, make as straight as possible, then with a pair of needle nose or any pliers you have, go about a half inch in from the hook side. Make a U bend, about the same size and shape of the end of a paper clip. Go in drain a inch and turn hanger in a circle trying to catch the hair blockage. Twist a couple times and pull back gently, do not push hanger in to far, you might break your pipe or the hanger may get caught in the p-trap or even worse drum-trap,(older houses tend to have drum-traps, I suggest not to even attempt to clear any blockage were a drum-trap is involved,call a plumber)
If its hair, you will see this black sludge looking hair ball that may make you sick. Don't worry you'll be happy when all is said and done, and you can shower without standing in your own filth. If its not hair, you probably have a more serious problem. Call a plumber and make sure your plumber gives free estimates.
Other Tips:
http://www.fixya.com/support/r5197305-stop_water_sweat_solder_water_line
http://www.fixya.com/support/r5238897-reset_toilet
http://www.fixya.com/support/r5245506-leaking_shut_off_valve_hard_close_shut
Plumbing Logo
Hair in a Jacuzzi Drain
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Mar 09, 2014 | Jacuzzi - Bathtub - Alcove - Navona -...
clogged shower drain
Shower drains are all designed to be opened and cleaned, usually hair builds up, if there is a visible screw remove it and lift the drain cover, if you can get fingers under the cover try lifting it off to clean it. If its stiff and its made of plastic do not use metal tools to lift it. Instead pass a trouser belt under both sides and use this to pull it up, then clean it.
Dec 04, 2013 | Home
toilet works fine,but drains for sink and shower stall drain very slow
hello there:
sounds like you may be having a partial block in you're drain lines do too paper and things being flushed down the toilet you may need to go to the outside of the house and find the cap on the drain vent and use an industrial snake and run threw the drain lines to get ride of the clog this should solve the problem you should be able to rent one from ace....hope this helps you out thanks
May 29, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Slow draining tub.
You need to run a snake through the overflow. I'm sure there is hair that is caught in it. You remove the overflow cover. The p-trap is just about 8 to 12 inches below. There isn't a need to go any further but it doesn't hurt.
Mar 21, 2009 | Maax Shower Drain 10000041-105
1,566 people viewed this tip
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
