Tip & How-To about Health & Beauty
Routine care at home to prevent the hair from damage.
  • Always keep your hair clean. It will protect them from dandruff, itching and hair lice, which ultimately results in hair fall.
  • Always use the shampoo and conditioner depending on your hair type. As for oily hair, you should use a shampoo, which is meant for specifically for oily hair.
  • Give regular massages to your scalp and hair with lukewarm oil at least twice a month. You can choose coconut oil, olive oil or almond oil for your hair. You can even mix these oil and apply the solution on your hair.
  • If there is dandruff in your hair you can mix camphor cubes in coconut oil to massage on your hair and scalp. It helps in reducing the dandruff.
  • Rub a lime on your scalp if there is dandruff on your scalp, leave it for 10 minutes and shampoo the hair. You should use medicated dandruff shampoo and oil to apply on your hair when they are suffering from dandruff.
  • Never comb your hair when they are wet. The roots of the hairs are the weakest when they are wet.
  • Keep the hair wrapped in a towel for a while then let them dry in natural air as excess usage of hair dryer too damages the hair texture and makes them weak and then ultimately they fall.
  • When your hair is falling, make a mixture at home containing Amla, Shikakai and dry neem leaves. Grind them together and apply this paste on the hair before washing them off for a while.
  • Whipped eggs mixed in curd and henna powder help in preventing hair fall.
  • Eat healthy diet including green vegetables, dairy products and fruits.
  • Drinking coconut water prevents the hair fall.
  • You can make oil at home for falling hair. Boil henna and neem leaves in mustard oil till the leaves get almost dissolved in it. Let it cool and then filter. Add few camphor cubes to it and fill in a bottle. Use this oil to massage on your hair.
  • Mixture of almond oil, olive oil and castor oil is equally good to prevent and stop hair from further falling.
  • Get your hair trim every month so that there are no split ends left.
  • Include at least 2 nuts in your daily diet. They help a lot in strengthen the hair.
  • Avoid using too harsh clips or bands on the hair. Never make hair too tight.
  • Protect the hair from dust and sun. Cover your head while going in the direct sun.
  • Apply hair pack on your head at least once in a month. It can be henna paste, curd, eggs or a combination of all.
  • Wash your hair every time you apply some chemicals on your hair in form of styling gels, creams, sprays or lotions. The harmful chemicals in them damage the hair and make them to fall.
  • If you have got the bald patches on your head then apply onion on the bald patch by rubbing it and then apply honey over it. Leave it for few minutes and then wash off.
  • Boil fenugreek seeds in any of the hair oil of your choice as coconut oil or olive oil. Restrain it and fill it in a bottle. Use this oil to massage on your head. Its very helpful in reducing the hair loss.
  • Eating iron rich fruits and food helps in preventing the hair fall. Include apples, beetroots and jagary in your daily diet. They are rich in iron so help to prevent your hair fall.
  • Eating amla in any form or drinking its juice too helps in preventing hair fall.
Follow these simple hair care tips and you can protect your hair from further damage
Health & Beauty Logo
Best home remedy for Dandruff
no home remedy get head and shoulders , it is the best , does not work the first time but does work , I had it for a long time and this is the only thing I found to work ,
Apr 21, 2015 | Health & Beauty
does neo leal hair tonic makes our hair to grow earlier and thicker
Yes it does.Neo Leaf Hair Tonic. Constant hair care with Neo Leaf Hair Tonic will enhance your hair and keep your hair and scalp in good order by the effective ingredients. Neo Leaf quality hair tonic protects the healthy scalp and hair, and earned a good reputation and favored among professional hairdressers as well as home users. Constant hair care with Neo Leaf will enhance your hair and keep your hair and scalp in good order by the effective ingredients. Possible results of using Neo Leaf: Elimination of itching and dandruff Prevention of depilation after sickness
Jun 13, 2011 | NEO Leaf Milbon Tonic Hair Tonic 4.1 Fl....
is it any side effect of this oil
Hello dear
There is no side effect of this hair oil infact, but if does not match your hair or scalp skin then it will have some harsh effect on your hair. First get and identify your hair type.
Well to check the oil that if it has any side effect on your head, first use it biweekly means twice a week for 14 days and stop using it. Then Check
Does your hair falling starts?
Do you feel itching on your scalp?
Do you see more dandruff on yur head.?
If all says NO, then use the oil care free.
regards
Feb 26, 2011 | Dabur 10x300ml Vatika Coconut Hair Oil...
653 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
