Tip & How-To about Computers & Internet
How to remove password from PDF?
Sometimes we may come across some PDF materials which were download from the internet or sent by others. They are easy to read by free Adobe Reader yet some of them were password protected from opening, copying and printing. It is really tough if you urgently need to copy or print some PDF files. So is there any method to remove PDF password? The answer is yes. But first we need to know some definition about PDF password.
Generally speaking, there are two types of password provided by Acrobat PDF standard security. They are "user password" and "owner password". "User password" is also called open password, it is the password defined by the people who create the PDF file which is used for protecting the PDF files from opening by others. Only people who enter the password can open the protected PDF files. "Owner password" is the password that set to protect the PDF files from changing by others. With an "owner password", the owner can protect the PDF files from printing, editing or selecting text and graphics.
So it turns to know how to remove password from PDF. Here is a small and easy-to-use PDF password remover which can help us do this work. Of course first you need to download this PDF password remover and install it on your PC. Then we can get start.
Step 1 Launch PDF Password Remover Double click the start icon to launch PDF password Remover.
Step2 Import PDF files
Click Add and browse the local PDF files need to be decrypted. It allows you to import 200 files at one time. After the files are imported, the file information will be shown in the panel.
Here you need to note that this PDF Password Remover can remove "owner password" directly. While for the PDF files with "owner password", you cannot remove the password unless you know the password. The "owner password" protected PDF files is shown in the pane with a lock beside. If you need to remove the "owner password", just click on the lock beside the file in the pane and key in the correct password in the pop-out small window box and click OK to confirm the password.
Step 3 Decrypt PDF filesClick the Start button, and soon you can get the decrypted PDF files.
Also there is a quicker way to remove PDF password with this PDF Password Remover, just right-click the protected PDF file and choose Decrypt with AnyBizSoft PDF Password Remover in the shortcut menu, you can remove the password from protected PDF file without launching the program!
Sincerely hope this tip can do you much favor to learn how to remove password from PDF.
Computers & Internet Logo
How do i download Adobe Acrobat x Standard for Free?
Acrobat reader is free. Acrobat pro is not free.
There are other free programs to create PDF's. Really, Adobe is offering the readers for all systems for free. Be aware sometimes PDF files are password protected. You even can't read them with acrobat reader, if you don't have the password. Just visit the Adobe website to download a free version for your system.
Now you can get the 11 version here:
Adobe Adobe Reader free PDF viewer download
Nov 22, 2014 | Cosmi Perfect PDF Creator Full Version for...
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded)
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
Adobe Reader 9 mine does not normally read pdf docs. It says the doc is corrupt or is sent by email!. what can I do to fix it
You have to download a new version of adobe reader and install it. You can download it from the below link
http://get.adobe.com/reader/
Thanks
May 21, 2010 | Computers & Internet
video convertor pdf file from creator 2010 cannot be read ? but video tutorial ok
In order to read a .pdf file, you will need a program enabled to open and read it. The most likely and FREE version is Adobe Reader which can be downloaded and installed by going to the Adobe site...
http://get.adobe.com/reader/?promoid=BUIGO
Be sure to UNCHECK the box above the download button that says "Free McAfee Security Scan (optional)"
Nov 06, 2009 | Roxio Easy CD & DVD Burning
232 people viewed this tip
David Payne
David Payne
