Tip & How-To about Hammering
Grounds? or Grounded?
When I bought my house was not a brand new one. my wife said "well you know about everything No?" So I had to prove myself. Fixer up houses could be a pain in our Royale ****! but us man will say yes I can do it!. One of the problem I address right away in my new use home was the electrical wiring. Old houses need to be upgrade their electrical wiring including main fuse breakers boxes. I went to my local hardware and found different gadgets & devices to help us Doit Yourself people. For a few bucks i found this plug in device that will give me different light blinking tones when you encounter a faulty wiring or open ground. It works, I found some open ground in my wall outlets and fix them. Open ground can cause electrical failure in your wiring which could affect all your electronics and appliances. Take your time to check for open grounds wiring in your home you won't regreted.
Call your local electrician for your electrical needs. Don't be a fool to try to fix things without the right knowledge & experiance in such matters.
Hammering Logo
How to repel snakes from my home
Robin,
I have heard that moth balls put around the outside of your house can be effective. I am getting ready to try this myself since my wife caught a snake inside our house this week.
May 30, 2015 | Bonide Snake Stopper Repellent
where is the thermostat
i just got a part that was connected to the thermostat housing.its just down behind the air filter.connected to the engine and intake manifold..you cant miss it.it has a little part on the top that is connected with 2 10mm bolts.i just learned this myself.hope it helps.good luck with your kia sedona.ive replaced just about everything.im just shy of a brand new one and i can assure you thats not happening.
Mar 25, 2012 | 2004 Kia Sedona
My Sharp EC-l2TWT4 throws belts and I noticed the motor shaft was not running straight. My wife took it to my local dealer in Brainerd,Mn and they said it was fine.So I took it apart and found the plastic motor housing had melted at some point letting the motor twist out of alignment. Other than this, everything works great.Can I order this plastic housing piece somewhere?
I checked the schematics for that model and the motor housing for that model is no longer available. Your best bet is to either attempt to find a used part or trade it in and get a new unit. Sharp no longer makes any vacuums or parts which makes these almost obsolete because most of the parts are discontinued.let me know if you have any other questions or would like to talk about recommendations. thanks, chuck
Jan 09, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
808 people viewed this tip
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
