Tip & How-To about Cell Phones
IPhone bluetooth to Blackberry VM605 visor speaker
Couldn't get them to pair... then tried this: On the VM-605, Press the FM key (left hand side) and the Volume key Right Hand side for 4 seconds. After 4 seconds the the VM-605 says "In Pairing Mode", you can there search for the device on your Blackberry in Blurtooth mode and it will allow you to pair using the default key of 4 x zeros
Cell Phones Logo
how do i turn off safe mode on a samsung galaxy ace
Safe mode in Galaxy Ace s5830
To START "Safe Mode" use both hands to Press the Home Key (bottom centre) and then simultaneously Press BOTH the Power (right hand side) key, and the Volume-Up (left-hand side) key. When the Samsung Galaxy logo appears, release the sides' Power and Volume-Up keys but keep the Home key pressed. Safe Mode should come on shortly. SIMPLY DOING THIS SAME KEYING SEQUENCE, WHILE THE PHONE SHOWS "SAFE MODE" IN THE BOTTOM LEFT CORNER OF THE SCREEN, SEEMS TO TURN THAT "SAFE MODE" OFF. Safe Mode prevents Third Party Apps running, apparently.
Apr 18, 2012 | Samsung Lands Phones
i need to increase e72 volume
To increase the volume dial a number on your phone and press the right hand side of the navigation key. You can also press left hand side of the key to decrease volume
Jul 12, 2011 | Nokia E72 Smartphone
I cant hear when people call me and i cant adjust ring volume Thankyou for your assistance
Hi
Dial the number and press the right hand side of the middle key to increase the volume and the left hand side of the middle key to reduce the volume.
Goodluck.
Aug 31, 2010 | Sony Ericsson T303 Mobile Phone (Shadow...
iphones bluetooth doesn't work
Go into settings & press about. Scroll down to bluetooth & if it shows a address it should be working if not then it is not working & just do a network restore.
Jun 11, 2010 | Apple iPhone 3G
jensen vm 9312 region code
You can get into the master system by using your remote. 1.Make sure your Jenser VM9312 is on, and select AM/FM as your source. 2.On your remote, press the Setup button, located on the lower right of the remote, you should hear a beep from your VM9312 when you press the button. 3.Now, making sure you hear a beep after every key press, press, 543210. NB:If you did this correctly, a new menu screen will pop up. 4.On the display, press the hammer and screwdriver icon, located on the left hand side of the screen.
NB: Here you can bypass the break and regions etc. When done Press the X at the lower left of the screen and enjoy.
Feb 01, 2009 | Jensen's VM9312 Car DVD Player
2,077 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
