Tip & How-To about Office Equipment & Supplies
Printers, Printers & Printing..
One of the most common problems with printers is to you know your printer? Complicated devices running on electical pulses. You always need to service your unit once in awhile to keep it going. My favorite is to: (1) Blow of with a compress can of air to blow off particles stuck thru the runners & cracks. (2) Always run your diagnostic program of your printer to chec for anything that you may need to do and to make sure that your cartridges are align as require.
Try that too..
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and still doesn't work. Help!
Hi!
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Regards,
Bogdan
Aug 21, 2011 | Office Equipment & Supplies
The lexmark printer is so complecated... The installation of my printer cannot complete because my computer cannot detect the printer.. How can i solve this?
First make sure usb cable and usb ports of computer is working fine. Then connect printer to computer then you can see found new hardware if it found then locate your cd drive or harddrive location whee the driver is saved. Also uninstall old driver if installed also uninstall all usb drivers from device manager for that press windows key +R key so you can see run type in run "devmgmt.msc" then press enter then you can see device manager then uninstall all usb drivers from there then it automatic installs all usb drivers. if you haven't driver then download updated driver from below link. Click here Let me know if you need further assistance. Thanks for using fixYa.
Jul 10, 2010 | Lexmark Z2320 InkJet Printer
MP520 error 6A90 - printer error has occured. Manual tels me to contact serviceman!
Before removal of the logic
board ***'y, remove the power
cord, and allow for approx. 1
minute (for discharge of
capacitor's accumulated
charges), to prevent damages
to the logic board ***'y.
Oct 08, 2009 | Canon MX700 Office All-In-One InkJet...
No matter what number i fax to I always receive a fax busy message. I have tried different phone jacks throughtout the house. What can I do to correct this problem? Thanks in advance!
Check in the fax setup menu and make sure that the setting for tone or pulse is set correctly for your area, most all systems now are set for tone dialing. Make sure you input the number just as you would dial it, like 1 before the area code and no area code if you are faxing a local number...
Aug 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
printer canon1700 shown message ''service 5100 error''
Call your dealer or servicing agent. The device has a hardware problem that needs to be addressed by a trained service tech.
May 05, 2009 | Canon Office Equipment & Supplies
206 people viewed this tip
k24674
jasbo
jasbo
