Tip & How-To about Audio Players & Recorders
Audio speakers connections?
They say that the best experience is learning from a bad one an it is true. When you connect speakers to your amps, car, or any other audio device you need to keep track of a few basic procedure. (1) make sure that cables to be use are the right gage for the audio to go thru without losing frequency. (2) make sure that when you connect the speakers to the amp or unit to be use, to keep in mind the polarization of each cable to be connected, example; usually in the area to be connectec there is a red & black connectors. red (+) positive Black (-) negative. Fallow the same in each cable by noticing the cable itsefl to make sure everybody is plug in the right way..
Remember " positive with positive / negative with negative"
iwave pod bluetooth speaker
Unless your PC is Bluetooth capable, you'll need to get a Bluetooth device to make it so. This is just one of many such devices to select from. Amazon com Roker Ultra Mini CSR Bluetooth 4 0 Usb Adator for PC and... They vary in size and price. Shop around to find one that best suits your budget. But you want an adaptor/receiver specifically for Bluetooth. (you will need an empty USB port for the adaptor)
Hope this information helps, best of luck!
Feb 06, 2014 | Audio Players & Recorders
This TV is lacking in the audio department. I'd like to add external speakers, but the only Audio Out appears to be the headphone jack. Can I hook up via a preamp to power external speakers?
What you can do is to look at the back of the TV and search for an audio out. The presumption here is that this TV is a newer Flat Panel and has too many connections on the back of the screen. It will be confusing, but it may be by itself and it will say "Audio Out" or "Digital Out" (Digital Out is best). If this is not true you can connect the Headphone out to the Pre-Amp through a 1/8th to RCA cable connection from Radio Shack. When you find it you can connect this output to your Pre-amp or AV Receiver with standard RCA cables or "Optical Cables" (Optical Cables are best) and really enjoy the movies with as much Butter on your Popcorn as you can stand but watch out when it gets scary because the Popcorn will fly.
Sep 18, 2009 | Televison & Video
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and negative connections and the same for the left speaker. I recently purchased a set of Polk Audio RTi A7's and each speaker has tow positive and negative attachments. The instrucions are not the most informative, but talk about Bi-wiring, or using separate speaker wire connections for high and low frequency section. The pre-amp will allow the use of two separate speaker systems. I have never had to use both and usually used speaker system A. Can I do as I have done before and attach a speaker wire from the pre-amp speaker system A to one right speaker positive and negative connection and do the same for the left or do I have to connect speaker wire to the two positive and negative connections on the right speaker using speaker system A and then do the same for the left speaker using speaker system B?
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
1,656 people viewed this tip
 Grubhead
Grubhead
