Tip & How-To about Viper Security and Remote Start System (basic install included)
Don't buy the 771
I had the 771 with remote start for 18 months it quit working needed replaced over 10 times it is junk,, i'm glad it has a lifetime warranty,, but you have to waste a day to take your car in find a ride home or wait 5 or 6 hours,, stay away from this model circuitcity also sales the same model it is our family mini van
Viper Security and Remote Start System (basic install included) Logo
My fridge is leaking a lot of water onto the base o f the fridge where the salad compartments are. I'm constantly mopping it up and it's no more than 18 months old. Does anyone know what might be causing this?
The warming and cooling cycle is off. Refrigerators cycle hot and cold, this allows the frig from not turning into ice. Remember the old days you had to leave the door open to defrost ?
There should be an adjustment at the bottom (in front) just below the front door side underneath the frig. Some have a knob, others have a screwdriver blade. Try that 1st, otherwise your compressor is going bad and not putting out the proper cooling. 18 months sounds awful short for a bad compressor. They can last a lifetime.
First I'd rush to find my warranty papers before time goes by, because no one will fix a compressor. Once a compressor goes bad it spells junk, buy a new fridge.
The other part that can go bad are the warming bulbs hidden in the walls, but usually the fridge stops cooling period when that happens because the electrical circuit is broken. One needs a closed circuit to make anything work. Also check if the compartment has a separate cooling adjustment, many have. The other thing to check is to look for
the cooling adjustment within the refrig itself, which controls the entire refrigerator. Turn it a notch at a time cooler. The main cooling adjustment is usually located on top in the upper portion within the fridge. Make a list of the items I mentioned, then check them off because I didn't give the causes in the exact order.
May 10, 2014 | Essentials CIFF7012 White 9 Cu Ft Fridge...
II[ have a Hampton Bay 53" fan with a lifetime warranty that has quit working -6 months ago I contacted customer support and they sent me a relay which I installed to no avail. What is my next step ?
Take it back to Home Depot with your receipt & don't buy a store brand fan.Don't buy the Hunter fans in there either as they are only made for them...
Apr 02, 2013 | Hampton Bay 52 In. White Redington...
483 people viewed this tip
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
