Tip & How-To about Microsoft Word for PC
Add Horizontal Lines in Word 2007 Document Quickly
You can add horizontal lines in Word 2007 document quickly without having to use the ribbon on the top of the page. A very easy way to add horizontal lines in Word 2007 quickly is by using the keyboard shortcuts. This method will save your time. You will be able to insert lines of many different designs by using the keyboard and not having to use the mouse at all. In order to add horizontal lines in Word 2007 document quickly, you can use one of the following procedures:
1. If you want to add a simple straight line, type three dashes (---) and press Enter on the keyboard.
2. For this style of a horizontal line, type three asterisks (***) and press Enter.
3. Type three underscores ( ___ ) and press Enter to get this line:
_____________________________________________________________
4. Type three equal signs (===) and hit Enter to get this line.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Microsoft Word for PC Logo
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
print preview makes excel 2007 stop working
The Smart Technologies Notebook Version 11 software certainly seems to be the culprit. Taking the cue from Bob Cochran, this is what is what I did and the problem has stopped. Open Excel and click on the Office button at the top left. Then Click on Excel options. Click on Add-ins. In the "Manage" window, select COM Add-ins and click Go. In the COM Add-ins window uncheck SMARTInk-Excel-All and click OK and "poof" problem gone!!!
Aug 21, 2012 | Microsoft Office Professional 2007 Full...
1,187 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
