Tip & How-To about Computers & Internet
How to reset your lost windows XP/NT/ 7 password
The World Cup is coming and you attemp to log in to your Windows xp,and realize you can’t remember the password?It is very annoying. What should you do when you lost windows password to login to Windows system?
It is easy to gain access to windows after losing your user account password.Just simply login as the computer administrator, and go to control panel->user accounts. There you will be able to reset the password for any of the systems user accounts.
Things get more tricky if you have lost administrator password, It's a sickening,powerless feeling to be locked out of your own computer though this happens more often,everytime we feel so helpless.What should you do in facing this situation.You have tried everything you could but failed.
In reality,There are a couple of ways you can gain access to your windows Adminitrator account.
Method 1: Windows XP and further versions also provide another method to recover forgotten password by using ""Reset Disk"". If you created a Password Reset Disk in past, you can use that disk to reset windows password.
Method 2: Use a password Reset Disk
To use the password Reset Disk to log on to the computer,you can follow these steps/ If your computer is current or former member of the domain, go to "domain Windows XP Professional" section and follow the steps.
Windows XP Home Edition or Windows XP Professional Restart the computer.In the Windows XP logon screen, click the user name you want to use, and then press Enter.Note: You will receive the following error message:“Did you forget your password? You can click the "?" Button to see your password hint.Or you can use your password reset disk. Please type your password again. Be sure to use the correct uppercase and lowercase letters.”
Click "Use a password reset disk." "Password Reset Wizard" starts. Through the "Password Reset Wizard", you can create your user account a new password.
In the "Password Reset Wizard" dialog box, click "Next."The password reset disk into the CD drive, then click "Next."
In the "Type a new password" box, type a new password, and then "re-type the password to confirm" box, type the password again.In the "Type a new password hint" box, type the password prompt, and then click "Next."Click the "Finish", then try to log on to Windows XP.
If you can reset your password, and now can successfully log on, you have to solve this problem, and completed all operations. If you still can not log in, please try Method 3.
Method 3:
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal windows password. However, I've tried a couple of these utilities through the years and my favorite is the windows password key 8.0. This utility is used to reset password of any windows versions.
1. Login to a computer that can link to Internet. Download windows Password key and install it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive.
2. Insert the newly created CD/USB to the locked computer.
3. Reboot the locked computer and press'F2'or'Delete'to enter your BIOS setup and then you will see the instruction
Now you can regain access your Windows operating system and create a new administrator password. The best thing of using this method is that you shouldn't lose any data on your computer. Furthermore, If you can't find a computer which has a CD/DVD writer or the locked computer have no a CD-ROM, You can burn the ISO image file into a USB flash drive and use the USB flash drive to recover your Windows administrator password.
Try these three methods the next time you have lost Windows administrator password, which you do not need to reinstall Windows system for getting back to Windows by removing lost or forgotten password.
Computers & Internet Logo
how to unlock my toshiba laptop/...don't know password
Right here we're going to deal with as one of our common annoyances for some time to come, crack laptop password based on any Windows including Windows XP/
7/Vista/2000/2003/2008.
Jul 19, 2011 | Toshiba Computers & Internet
how to reset password on my compaq computer!
Start pc in "Safe Mode With Command Prompt" When windows starts, type your log in name in the dos window with an asterisk. For example ( john * ) but with out the (). It will prompt for a new password. Reboot and Bam your in. If you cant remember a log in name exactly as it is, type in ( net users ) and hit enter.
Jun 13, 2010 | Compaq Digital PC 3100 PC Desktop
password
try tapping F8 when you turn on the system on the blue Dell logo,goto safe mode or safe mode with networking,log in as administartor,if you have'nt setup a password for administartor then click on OK without putting in the password,it will log you in,remove the password from your user account
Jun 22, 2008 | Dell Microsoft Windows XP Home Edition
Cant Log on my com. LOST PASSWORD.
This comes from Yahoo but the last time I recovered a lost pass I hooked the drive up as slave on another machine and used a program to search for the pass on the old drive.
Method 1: Take a rest, and try hard to remember the forgotten password
Sometimes, human being is a little weird. You won’t get the thing that you urgently need. So have a coffee, take a snap or even come back after a few days, you may found that you suddenly ‘remember’ your Windows password.
Method 2: Try No Password Administrator Login Backdoor
In Windows XP (not Windows Vista as Administrator account is not enabled by default), there is built-in Administrator user account, that has administrative credentials, enabled by default, and without any password to protect the account from been access. If you didn’t change this Administrator’s password, then try to sign in to Windows XP without password.
Method 3: Reset password from another user account with administrator credentials
If you cannot log on to Windows by using a particular user account, but you can log on to another account that has administrative credentials, follow these steps on how to do the trick:
Log on to Windows by using an administrator account that has a password that you remember. You may need to start WinXP in safe mode.
Click Start, and then click Run.
In the Open box, type “control userpasswords2′, and then click OK.
Click the user account that you forgot the password for, and then click Reset Password.
Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Method 4: LOGON.SCR password reset trick
LOGON.SCR changing administrator or domain admin password hack works on Windows NT 4.0 and some versions of Windows 2000. The simple trick uses Cmd.exe as screen saver that triggered by system when idle, allowing users to access to command prompt to change password.
Method 5: Do-It-Yourself (DIY) third party recovery tool
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal existing password. These password reset or retrieval utilities, free or paid, are usually a Linux boot disk or CD that able to comes with NT file system (NTFS) drivers and software that will read the registry and rewrite the password hashes, or can brute force crack the password for any user account including the Administrators. The advantage is that there is no fear of leaking your password to outsiders, while the process requires physical access to the console and a floppy or CD drive, depending on which tool you choose. And it’s not easy, although it always work!
Offline NT Password & Registry Editor - Available as bootdisk or bootable CD, Offline NT Password and Registry Editor works to change or reset password of any users on Windows NT 3.51, NT 4, Windows 2000, Windows XP, Windows Server 2003, Vindows Vista 32 and 64 bit. It can also detect and offer to unlock locked or disabled user accounts.
May 03, 2008 | Computers & Internet
147 people viewed this tip
David Payne
David Payne
