Tip & How-To about Computers & Internet
Lock laptop?
Laptops are touchy gizmos but the worst is when they lock on you. My quick solution is when my lock on me and can close any programs or turn it off just simply take the battery from the back for a few and replace it back again then start up your laptop. She will reboot it self and go to a safe mode or your standart window.
Don't forget the battery?
Computers & Internet Logo
reset key fob
Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again
Jul 22, 2014 | Subaru Outback Cars & Trucks
I have an HP G72 and the touch pad frequently locks up...help me fix this the FN and F9 combination didn't help.
tricky huh!!! you simply have to quickly double-tap the Touchpad light :) to lock it or unlock it :) hope it works for you :)
Nov 10, 2010 | HP Compaq nc6000 Notebook
programming instructions for keyless remote Does anyone have the programming instructions for 1998 honda passport keyless remote (FCC #HYQ1512R)?
Get into your passport and unlock all doors. Leave drivers door open. Put key into ignition. Turn to ON (not start), then OFF three times within 5 seconds. Close and open the drivers door twice. Turn key to ON then OFF 5 times within 5 seconds. Close then open the drivers door. Press either the lock or unlock button on the remote. Doors will lock then unlock. Press the button again. Doors will lock then unlock again. Close door to finish programming. If it doesnt work, try it again but turn the key faster. You have to do it all pretty quick, but I had it done on the second try.
Oct 03, 2009 | 1998 Honda Passport
touch pad is too touchy
Check in the control panel and get in the mouse program, usally there is the program of your touchpad.
Feb 12, 2009 | HP Pavilion ze4300 Notebook
how to program the key for my bmw 750i model 1997 to lock/unlock the door
BMW 7-Series - Key Remote Programming
Three methods to try:
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
window.google_render_ad();
Dec 16, 2008 | BMW 750 Cars & Trucks
213 people viewed this tip
David Payne
David Payne
