Tip & How-To about Computers & Internet
How to Log on Automatically to Windows 7 Without Typing Password
In this tutorial I will tell you how to configure Windows 7 OS to automatically connect without prompting you to enter your login password each time user account. Although in this example can be found on many other sites, we have decided to publish them. The problem with other similar guides is that they are not complete and not to give you all information you need to know. So I will try to guide you through all stages and share them with you all the information you need to know in order not to ruin the computer.
First, open the Run window by pressing the Windows key + R or launch the Command Prompt. Type one of the following two commands: netplwiz.exe or control userpasswords2. No matter which one you use, they have identical results and launch the same window.
Once you run the command, a User Accounts window similar to the one below will launch. There you will see the list of users registered on your PC. Select the user for which you no longer want to type the password in order to log in to Windows 7. Uncheck the option which says 'Users must enter a user name and password to use this computer' and click on OK.
Now you will be asked to type right user password of the user twice. After done, click on OK.
The next time you will start Windows 7, you will be automatically logged on with the user you just selected. This user will become the default log on user to Windows 7.
IMPORTANT NOTES:
If you have multiple users on your PC, the definition of that definition could be a disadvantage. Windows 7 will still automatically connect to the user that you selected during this procedure. Sign in to join to have another user wait for Windows 7 to boot and connects you automatically to disconnect, then the other user you wish to register. If you set things on how they followed the same procedure and make sure you check the option which says 'Users must enter a user name and password to use this computer'.
If this Windows 7 PC has joined a network domain, such as a company network, this procedure will not work. In network domains, the policies regarding the log on procedure are set by the network administrator and cannot be overwritten by users. If you try this on your office computer, there is not way.
Related: Windows 7 Password Recovery
Computers & Internet Logo
I forgot my laptop password
You can try the following:
If your S.O. is Windows you can try any Windows Password Recovery Tool
Alternatively you can ty( if Windows):
Step 1: Boot or Reboot your Windows laptop (it is a Windows 7 example ).
Step 2: Hold on F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Or Press CTRL to enter Advanced Boot Options when computer power on.
Step 3: Choose Safe Mode with Command Prompt in the coming screen, and press Enter.
There are three options for choice, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. In order to reset Windows user password with command prompt, select Safe Mode with Command Prompt.
Step 4: Wait for Windows 7 to load files until Windows login screen comes out.
Step 5: Log in with an administrator account or built-in administrator when you see login screen.
Step 6: Command Prompt runs automatically. Type net user in the Command Prompt and press Enter to see how many user accounts in locked laptop. Then all of laptop users will be listed in the Command Prompt.
Step 7: Choose one administrator to reset forgotten password for laptop.
Type net user fuzi 123 and hit Enter. Suppose 'fuzi' is your locked Windows user name. Then '123' would be new password you reset for it.
Step 8: Login your laptop with the new password after successfully laptop password reset.
Sep 30, 2016 | Computers & Internet
I forgot my password and I can only log in as a guest
You can try the below given steps to reset administrator password using guest account (you must have write access to system32 file):
1. Navigate to location C:/windows/system32
2. Copy cmd.exe file to desktop and rename it to sethc.exe
3. Now copy this sethc.exe file and paste to system 32 (when windows asks for overwriting click yes).
4. Log out from guest account and at user login screen press shift key 5 times.
5. It will open command prompt with full administrator privileges.
6. Now type "NET USER ADMINISTRATOR xyz123" (where "xyz123" can be any password according to your choice) and press enter.
7. You will see "The Command completed successfully" and then exit the command prompt and login into administrator with your new password.
If you don't have write access to system32 file then you can use stellar phoenix password recovery software to reset administrator password.
Nov 12, 2012 | Computers & Internet
how to unlock my toshiba laptop/...don't know password
Right here we're going to deal with as one of our common annoyances for some time to come, crack laptop password based on any Windows including Windows XP/
7/Vista/2000/2003/2008.
Jul 19, 2011 | Toshiba Computers & Internet
327 people viewed this tip
David Payne
David Payne
