Tip & How-To about Cat5e 100 Foot Shielded STP 350mhz Network Cable with Boots (C5SB100GRAY)
My cat 5e
How to terminat cat5e cable either crossover or direct terminiting and how to arrange them fix it with the rj45
Cat5e 100 Foot Shielded STP 350mhz Network Cable with Boots (C5SB100GRAY) Logo
standard cat5 wiring doesn't match philips rj45 flush mount
Are you looking for cat5 straight through cable or crossover??
option 1 (straight through)
each pin correspond to the other end in the same spot.
If all the cables are colored the same then you need an ohm meter to identify them.
Option 2: (crossover)
Pin 1 correspond to pin 3
Pin 2 correpond to pin 6
Pin 3 to Pin 1
Pin 6 to Pin 2
or you can go to (for schematics):
http://www.duxcw.com/digest/Howto/network/cable/cable5.htm
Nov 21, 2008 | Computers & Internet
network cable stopped being recognized
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)a796c91.jpg
Jun 28, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
662 people viewed this tip
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
