Tip & How-To about Computers & Internet
How to Protect Your USB from Receiving Virus
If you want to protect your USB from receiving unwanted files i.e. virus, worm, spy, trojan etc than you are at the right place.
What I'm gonna tell you is that how to setup your registry to stop a computer from saving files to your USB (It'll block all of them)
If you have windows XP with SP2, then you can disable the writing option to USB drives. This trick is very useful if you have virus in your computer and want to copy files from a USB Drive but don’t want to transfer virus to the USB. Follow the given steps to disable the USB writing option:
To edit the computer registry, first you should log onto your computer with administrative rights.
First click on Start button and type “Regedit” in Run option.
Here locate the location to:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControl
Here in right side panel, click right to create a key with the name “StorageDevicePolicies”.
Now in left side panel, select “StorageDevicePolicies” key, again right click to create new DWORD value then label it “WriteProtect”. Set its value to “1?. But again to enable writing, set its values to “0?.
Now close the registry editor
Note: If it won't work then restart your pc
Alternative way:
TO TURN ON THE PROTECTION
open notepad and copy and paste the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies]
"WriteProtect"=dword:00000001
Now save the file with the extension ".reg".
Double click on the file you just saved. In the pop-up window click YES and then OK.
That's it your USB is now protected
To TURN PROTECTION OFF:
"WriteProtect"=dword:00000000
That's it your protection is now disabled.
Computers & Internet Logo
My Dell Inspiron E1505 will be on for half an hour to an hour before Windows Explorer (and pretty much everything else) stops responding and I'm forced to turn it off. I've run registry cleaner, antivirus, and anti-spy/malware programs, but none of it has helped. Is there any solution to this problem?
Hi vincent172...
I think you have a virus,worm,trojan,etc on your computer.
Go to the following website and download,install and run the FREE Microsoft Safety Scanner.
It will remove the virus,trojan,worm,etc from your computer.
It may take quite a while to finish, it all depends on the size of your hard drive.
Once the Microsoft Safety Scanner is completed running, it should have removed the virus,trojan,worm,etc. from you computer, but if it didn't remove the virus,trojan,worm,etc from your computer then it will give you an option to connect (real time) with a Microsoft professional (FREE) and he will take over control of your computer (with you permission) and finish the removal process.
Please take time to rate me thumbs up
http://www.microsoft.com/security/scanner/en-ca/default.aspx
Sep 17, 2011 | Dell Computers & Internet
CANT CLEAN UNWANTED COOKIES AS I WANT TO CLEAR UNWANTED FILES
Hi malachyfinne...
To clean your files and to clean any cookies,virus's,trojans,worms,etc you may have on your computer do the following.
Sep 15, 2011 | Compaq Presario CQ62-112TU
my computer keeps telling me that my files are corrupt but i still can log on to the internet, windows pop up on every screen log on to.EVERY FILE!!!!!!!!!!!!!!!!!!!!!!!!
Hi yolandaskidm...
Sounds like you have a virus or maybe a trojan/worm/etc. on your computer.
Go to the following website, download, install and run Microsoft Safety Scanner.
After you have it installed the run the program, it may take quite a while to complete depending on how many files you have on your computer.
Once you have it installed you will run Microsoft Safety Scanner.
It will remove the virus/trojan/worm,etc from your machine for FREE.
If it does not get rid of the virus/trojan/worm/etc then a window will open and allow you to contact a Microsoft professional (FREE) and he will take over your machine (with your permission) and remove it for you for FREE.
Aug 22, 2011 | Dell Inspiron 531s Desktop Computer
510 people viewed this tip
David Payne
David Payne
