Tip & How-To about Computers & Internet
Get Your Devices Recognised by Computer
Make Sure to Check for your device's drivers in case, its not being recognised by your computer.
Computers & Internet Logo
need drivers
This is shooting from the hip since I don't know your operating system. Open the control panel and go to Hardware and Sound. Next, click on sound. You should see a device listed under Playback. If not then you are missing the driver for your sound card. If that is the case you will need to go to PC's manufacturer web site and download the necessary drivers. If this is not the case then you can go back to control panel under Hardware and Sound and under the first item is Device Manager. Open this up and check that there are no devices with a flag. If you do find one with a flag then open that category and select device then right click on it which will give you the option of updating the drivers. Hope this helps.
Mar 02, 2014 | Cyber Acoustics CA-2014 Computer Speakers
my edrive isn't being recognised by my computer.
if your e drive is a usb drive
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Jul 02, 2011 | Dell Computers & Internet
Emachines EL1850 internet connection problem, brand new out of the box computer will not connect to the internet. Its not the modem or an internet problem, as i'm using the internet and modem to write this. The computer seems to not recognise the modem Help
hi,
other computers are working fine in your modem?in that case you need to check if your pc can detect the modem,or you can check if the ethernet driver (for LAN connection) and/or wireless driver (for wifi) are installed correctly...you can check that in the device manager if the drivers are properly installed
if Windows 7 - click start ; on the start search area, type device and the look for device manager
look for network adapters and you will see there you lan and/or wireless adapter
Thanx
Jan 05, 2011 | E-Machines eMachines Desktop PC
IRQL_NOT_LESS_OR_EQUAL
The irql_not_less_or_equal error in most cases means a resource conflict, but there can be different causes. Check the temperature first to make sure you are not overheating it. Clean the inside if required, as dust may cause overheating.
If you get some .sys file mentioned on the blue screen, you know it is related to a specific device. Reinstalling the driver could help in that case.
Jun 04, 2010 | EPoX EP-8KRA2+ Motherboard
Problem with Toshiba MK8025GAS hard disk
check the connection of the hard disk and make sure the cable is properly connected. also chek the setting on the CMOS. it should be recognised at CMOS level, make sure it is set on auto
Aug 21, 2009 | Computers & Internet
128 people viewed this tip
David Payne
David Payne
