Tip & How-To about Computers & Internet
Hack windows xp
Here are the steps involved to De Hack or restore the Window XP Administrator Password to cover your tracks.
  1. Go to Start –> Run –> Type in CMD
  2. You will get a command prompt. Enter these commands the way it is given
  3. cd\
  4. cd\ windows\system32\temphack
  5. copy logon.scr C:\windows\system32\logon.scr
  6. copy cmd.exe C:\windows\system32\cmd.exe
  7. exit
Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click Yes to overwrite the modified files
Computers & Internet Logo
how to break xp admin password with limited account.. what ever i try to do it says access denied.. when i go to safe mood it says type Admin password. plz help me...
Did you try blank password when you are prompted to enter the admin password on the Safe Mode logon screen? If not please try it, most pcs admin password is blank (empty). Good luck. Thanks for using FixYa.
Jun 12, 2010 | Computers & Internet
a computer expert change my admin password. how I break that password
Here are the steps involved to Hack the Window XP Administrator Password .
  3. cd\
  5. mkdir temphack
  6. copy logon.scr temphack\logon.scr
  7. copy cmd.exe temphack\cmd.exe
  8. del logon.scr
  9. rename cmd.exe logon.scr
  10. exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here is
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
i have changed a new password for my administrator account and foget the password, i can only log through the user account. pls help me with steps on how to reset the password and enter new one
Do you need to reset vista or xp users password? Ihas a little trick that dig it for you from tech-hack forums. The method is very easy to follow and doesn't require any complicated commands. The method is free to use and you don't need to pay hundreds of dollars for some utility for unlocking lost windows passwords. Just follow next simple steps:
First thing you need to do is to start command prompt or CMD. There is two ways to do that:
Press F8 when Windows XP start up (before windows xp logo - progress bar for loading) and choose "Save Mode Command prompt" option
If you are logged in: click on start -> Run, type "cmd" and press ENTER.
In command prompt window type command "net user" or "net users". You will see the list of users that are created on current running OS.
Type "net user" "user name" "*". You will see that windows will ask you to enter new password for that particular user account! No super user privileges needed. Just type new password two times and you are done.
Example of process: If the administrator username is "administrator" then command for changing its password will be: "net user administrator *".
Note: quotes (") in the post are just for highlighting the word.
Nov 02, 2009 | Microsoft Windows Vista Ultimate Edition
administrator password
Passwords. Those ubiquitious alpha-numeric codes that protect us and give us access to everything digital. Unfortunately, passwords can be confusing because, though your computer likely won't forget a password, you very well might. When this happens, you can be locked out from your whole system, as in the case of the Windows XP Administrator Password. This article will show you how to remove an Administrator password.
Instructions:
Insert your Windows XP CD into your CD drive and boot your computer. If you receive the message "press any key to boot from CD," press any key.
Step 2 Press Enter to setup Windows. After accepting the license agreement, you wil be asked if you want start a Repair process.
Step 3 Press R to begin the Repair process. Setup will now check your disks and then start copying files, which can take several minutes. After this, reboot. Let the computer boot normally (do not press a key to boot from CD).
Step 4 Keep your eye on the lower left hand side of the screen. When you see the Installing Devices progress bar, press SHIFT + F10. This will open a command line console.
Step 5 Type NUSRMGR.CPL at the prompt and press Enter. This will give you access to User Accounts. Remove or change your password. Write it down! After the repair is finished, you will be able to log on with your new password.
Second way:there is some recovery tool like Windows Password Recovery Tool 3.0 http://www.windowspasswordsrecovery.com/ can help you.
If i am helpful please rate me.
Thank you.
Mar 08, 2009 | Intel D101GGC Motherboard
164 people viewed this tip
David Payne
David Payne
