Tip & How-To about Office Equipment & Supplies
How To Use Refilled Cartridge When Canon Pixma328 Detected Cartridge Errors!
How to use refilled cartridge when Canon PIXMA MX320 series detected already errors in your cartridge?
I have a canon Pixma328 and have been refilling ink for black and color cartridges for quite sometime now. The cartridges are close but after I drilled a small hole on the top part of the cartridge using a small screw, there I find a way to refill the ink that I bought from an ink refill store. The procedure needs extra care, not to touch the contact point (copper) because its sensitive and not to damage the inner part of the cartridge when I insert the needles of the syringe used for transferring ink.
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
You can print as long as you want, refill the ink as long as you want and save a lot of money from buying a genuine canon cartridge by just following this simple tips for Canon Pixma MX320 and/or Canon Pixma MX328 all-in-one printer
For those who have replaced their ink cartridge before try to use that again and do follow this tip to make that work again.
i refilled ink cartridges but printer/computer think the ink has run out
This model Canon printer may only let you use genuine Canon/Epson printer cartridges. If you try to refill these ink cartridges it will not work because the Canon cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Feb 12, 2013 | Canon PIXMA MX320 Color USB InkJet Printer
Canon Pixma MX320 - How To Disable Ink Cartridge Error Detection..
Wow, had to look through a couple of Google pages to find this! Thanks a lot - the 2nd suggestion worked! SPREAD THE WORD!
Jun 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
I'm getting an error V150 when trying to use my Pixma MX320 printer it states that I need to check the ink, yet both ink cartridges are full? any idea how to erase this error message? Or does this mean one of the cartidges may be damaged? The black cartridge was low on ink but I refilled it now there is this error that appears and I cannot seam to clear the message.
Error U150 refers to a cartridge not being recognised. This is due to the refilled cartridge. The machine knows that the cartridge has already been used and is expecting a new one. Some people say that if you hold down the stop key for 3 seconds when powering up it will remove the cartridge check. I have never tried it personally.
Jul 10, 2011 | Canon PIXMA MP180 All-In-One InkJet...
my canon mx320 multi function printer doesnt want to scan. it shows a U051 code and refuses to work.does a printer need tp have ink to scan?? i dont think so. pl help
Need to reset the cartridge.
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U041, U042, U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
For error U162 or U163 All functions of the all-in-one printer will stop and your printer will not work.
Please give this solution a good ratings. thanks
Dec 06, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
How do I reset the cartridges after refilling?
There are two ways to reset the detection of the cartridges.
1. to reset it after refilling the ink cartridges. This is use to avoid the printer from detecting the cartridge as reused one.
2. to reset it after the ink from a refilled cartridge ran out and the printer successfully detected it and disable your printing function.
Follow the complete steps on the reset procedure in My Helpful Tip I Posted Here In Fixya.Com. just click the link below.
http://www.fixya.com/support/r5191523-canon_pixma_mx320_disable_ink_cartridge
Aug 05, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
1,716 people viewed this tip
jasbo
jasbo
