Tip & How-To about Computers & Internet
Checking for updates results in an error message (0x8024001D)
Running windows update, Express or Custom it does not matter, when checking for updates an error message (0x8024001D) saying “the page can not be displayed” occurs.
Rename the SoftwareDistribution folder:
Stop the Automatic Updates Service
Go to Start>Run and type in: services.msc
Click on OK or hit ENTER
In the right-hand pane of the Services window, right-click on Automatic Updates and then select Stop
Now, navigate to C:\Windows (C:\WINNT, if using Windows 2000) folder, locate and rename the SoftwareDistribution folder to SDOLD
Restart the Automatic Updates Service by re-opening the Services window,
right-click on Automatic Updates and then select Start.
Please note that a "side effect" of renaming (or deleting) the SoftwareDistribution folder is that you will lose your current Update
History listing.
Found solution here:
http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.windowsupdate&tid=b5f7cbb5-4307-42a1-b3dd-8b259937525e&p=1
Computers & Internet Logo
error message while tryinh to instal broadband says 'No NIC has been installed on this sytem'. working with rather old Compaq Presario S0000
You need to update your drivers for your ethernet card. You can try running Windows Update to find it, or you can search for it on Compaq's website.
To run Windows Update: Go to your start menu and find "Windows Update". Click on it and do everything it asks you to do. If it asks you if you want to run Windows Update Express or Custom, pick CUSTOM. This will take a while. When it is done it should show you many, many updates available. Make sure to click "Hardware" on the left side under optional updates. This will usually have the drivers for your Sound and many other items. Check them all then "Review and Install Updates". Good luck!
May 05, 2011 | Televison & Video
prescott-533 can support sp-2
If your running windows with SP1 now without problems, there is no reason for SP2 or SP3 not to function correctly. Hint! When updating do not click the Express button in windows update. Click Custom. Try to download .Net framwork updates first. Continue using the custom button in windows update mainly for .Net framwork updates.
Happy holidays!
Mike
Dec 16, 2009 | Intel Motherboard
receive error code 0xc 0000135
Your operating system may need microsoft .Net framework. Check windows update. When it loads do not run Express, click on Custom. Download
.Net framework in order if possible. Continue the same untill Custom no longer shows updates for .Net framework.
Here is a microsoft link for error 0xc0000135. http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=error+0xc0000135
Happy holidays!
Mike
Dec 11, 2009 | Microsoft Windows XP Professional for PC
Update service pack 3 access is denied.
When you launch Windows Updates, don't choose the Express Updates but choose Custom. Then when you are presented with Service Pack 3, there is the option to not select it and then choose to continue to see what other updates there are. Personally, I do not recommend Automatic Updates or Express, always do it manually and always select Custom so an unwanted update doesn't get in under the radar and cause further problems. The rule of "if it isn't broken, don't fix it." really goes well with PC's.
Oct 15, 2008 | Microsoft Windows XP Home Edition
141 people viewed this tip
David Payne
David Payne
