Tip & How-To about Computers & Internet
Dell Latitude Portable model E6410 ? Bluetooth 375 will not connect
Problem: Dell Latitude Portable model E6410 – Bluetooth 375 was not connecting properly to users headset using Windows 7.
Resolution: Issue was resolved by updating the BIOS to the P02 patch then updating to the A03 BIOS revision (The P02 Patch is required before flashing to A03) then uninstall the Dell Driver Widdcom (Bluetooth 375 driver), Reboot the system and Reinstall the Bluetooth Driver (A BSOD was encountered after the driver was reinstalled, but system rebooted normally afterward).
After BIOS and driver were updated, Bluetooth worked normally.
Computers & Internet Logo
how to find my blue tooth in my dell latitude e 6410
First you have to make sure your bluetooth software is installed.
Dell Wireless 375 Bluetooth Module Application is what is called.
go to :
http://www.dell.com/support/home/us/en/04/product-support/product/latitude-e6410/drivers
scroll down to the work Network (6 files) in blue lettering on the list
select Dell wireless 375 bluetooth module application
download it Run it.
Dec 11, 2013 | Dell Latitude E6410 Laptop
E6410 Bluetooth randomly shuts off
The mouse is the issue, check all connections and battery contacts, if unit can run on standard battery, " replace " to see if that will help, and make sure wfi plugged into laptop properly,also try another usb plug on your laptop.
Apr 02, 2012 | Dell Latitude E6410 Notebook PC Core i7...
good mornning , i have dell d620 laptop (latitude) and i removed the original vista windows were on it when i bough it and installed windows 7 , i need to know is my laptop model match with window 7 or no , cos i have speed problems ,also the bluetooth is not working. thank u
All the vista drivers can be used for 7. By default, windows 7 installs all drivers except for touchpad.
You can find 32 bit version for it here
The 64 bit of Windows 7 64-bit ALPS touchpad driver from the Dell support site for a Latitude E6410 is reported to also work for D620. Give it a try.
May 11, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
I need the technical specifications
This Dell WEB site has the specification of the Dell Latitude E6410 -
http://www.dell.com/us/business/p/latitude-e6410/pd
Feb 09, 2011 | Dell Latitude E6410 Laptop Computer (Intel...
1,191 people viewed this tip
David Payne
David Payne
