Tip & How-To about Computers & Internet
How to connect wifi phone to the internet using your laptop w/ DSL connection/broadband
What do you need?
mobile phone with WIFI
pc with wireless NIC (network lan which is wireless) usually the laptop have this...
DSL connection of course.
Here's the step:
just follow the images.
then after that... close the window
in your mobile phone....
scan the wlan.. then it will automatically detect the myinternet connection.. connect there and start browsing
Computers & Internet Logo
how do i get wireless internet on my phone
Pls define the phone Brand/model.
In general, there are 2 means of "wireless internet:
a) Through DATA plan of your mobile provider
b) Through Wifi
Let's see how to reach these 2:
a)
Data plan means that you can get DATA through your mobile connection. So you need to check your contract or ask your mobile provider if you already DO HAVE a DATA PLAN activated. If not, pls do so.
You also need to make the needed settings change in the phone (set APN,e.t.c.) based on the instructions by your mobile provider.
Take into account that in general a DATA PLAN costs much more than a LANDLINE internet connection (e.g. a DSL connection) that you could have from your home, so it's OK for mail and faceboko browsing but perhaps too expensive to download movies, games, e.t.c.
b)
Wifi is a wireless local area network. It can be password_protected or Open. Usually cafeterias and other shops or central squares offer Open Wifi for everyone to connect to.
Also, when one has a Landline DSL connection, there is a Wireless router installed, giving the possibility to connect to this DSL wireless (with WiFi).
So you could even connect to your neighbor's wifi if that is Open.
Pls rate this solution.
Many thnx.
Nov 21, 2012 | Cell Phones
how do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
cant get on the internet
Heelo,
we need more information then this.
What make and model laptop, operating system etc.
How are you wanting to connect (wired or wireless) which make and model modem you have and they type of internet connection (ADSL, cable etc)..
Feb 17, 2011 | Computers & Internet
i want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
-IP: 10.0.0.1
-Subnet: 255.255.255.0
TCP/IP on iPhone
-Static IP
-IP: 10.0.0.2
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Computers & Internet
322 people viewed this tip
David Payne
David Payne
